Author Topic: How can i remove the sideskirt?  (Read 11619 times)
mong00sehun
  • Hungary
    • 2.6 V6
« on: 11 July 2025, 12:35:02 »
Hi guys,
i would like to repair the rust patch around the rear wheel.
how can i remove the sideskirt, and the rubber line? there are 2 rivet like thing.
Re: How can i remove the sideskirt?
« Reply #1 on: 11 July 2025, 12:53:37 »
Push the centre of the rivets through and retrieve them from the floor/behind the end cap.
Then undo the torx screw under the front end of the sill cover and pop off the little black caps along the underside of the cover.
Then, using your foot, tap the cover forward along the car until it falls off.
Trying to remove the cover any other way is likely to result in broken clips which have been unobtainable since 2012.
Migv6 le Frog Fan
  • Essex / Suffolk border.
    • 3.2 Elite. Nissan Leaf.
« Reply #2 on: 11 July 2025, 15:48:59 »
From memory - the black rubber strip can be just prised off gently ?
« Reply #3 on: 11 July 2025, 20:49:53 »
This :y
It kinda pops onto small studs.
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #4 on: 12 July 2025, 22:24:24 »
Hoof'land storeman.
mong00sehun
  • Hungary
    • 2.6 V6
« Reply #5 on: 12 July 2025, 22:57:33 »
thanks guys, ive been able to remove the skirt
i tried to repair some amount of rust, but it need a full sill change...
