Author Topic: Front strut spring identifcation  (Read 84379 times)
cam.in.head
  • West yorkshire
    • omega cdx 2.6 auto
Re: Front strut spring identifcation
« Reply #15 on: 28 August 2025, 12:15:33 »
yes i'm curious too .my std cdx springs (and cd too ?) are brown/silver dot .if the elite fronts are different i'd like to know (and get some !)
johnnydog
  • Lancashire
    • 3.2 Elite sal & est x3!
« Reply #16 on: 28 August 2025, 13:04:08 »
The front springs that came off my 2002 3.2 Elite did have two brown paint blobs, but also one silver blob of paint (which I didn't notice earlier).
Being curious, I cleaned the two that I took off my scrapper  2002 3.2 Elite (which was also used by the Police, but in Leics as a Staff Officers vehicle, so it is all standard Elite spec rather than Police spec) had standard 912249 /50 LM/RM struts, and the springs had the same two brown and one silver blobs of paint.
Incidentally the front springs were all 373mm long (give or take a fraction of a mm).
« Reply #17 on: 28 August 2025, 15:08:35 »
The Elite springs are softer. The shocks are the same as Non Plod/non LSC.
There were a few later retail Omegas in Police use as they missed the cut off for the final production run so we're forced to buy retail cars from dealer stock. TVP and Scotland got pretty much the entire final production run of RHD Plod spec cars.
Can't help on the colours, my plod still had it's original springs at 265k miles, I put Irmscher springs and shocks on my 3.2 Elite estate because the originals were done at 150k. My 2.2 GLS estate got Sachs shocks and Kilen HD springs because the originals were done at 125k. My 2.2 Sport had it's original LSC suspension on it because it had only done 28k.
The other 10 or 12 cars I did suspension work on either reused the springs on the car as they were or fitted Kilen/Eibach as required by the respective owners and if the springs were reused then they went back in their original position ie left or right.
There are, AIUI, the following variations:
1. Engine type: 4 pot petrol; V6/2.2 dti; 2.5 Dti.
2. Trim: GLS/CD/CDX; Elite; LSC (Sport/MV6); Plod etc.
3. Steering wheel side: LHD made allowance for driver and battery on left side.
4. Body type, although this only affects the rear as the options become saloon/estate; self levelling/non levelling/LSC/plod
Within the above matrix there may be some crossover regarding spring lengths and weights. The end goal was consistent ride height across the board (673mm rings a bell) or LSC (15/20mm lower) regardless of axle weight ÷ 2.
Aftermarket only allows for engine; standard, lowered or HD without the nuances of trim.
Irmscher allowed only for engine and body as their springs were identified by axle weight... An Irmscher catalogue of the time would give you an idea of the spring weights.
Standard springs will firm up an Elite slightly, and should be fitted if the self levelling is deleted, and Plod springs are a sensible option on cars used for load lugging or towing.
