Mercedes ML 280 CDI Project.
Started by Doctor Gollum, 08 September 2025, 23:56:32
I used a nail brush, but I can see how that would be a solution. :y
Actual leather to replace the MB Tex vinyl stuff is on the slightly longer term list. Had MB Tex in the Alabama Mumsybus and whilst fairly robust, it's just not the same. Seats would obviously come with the leather trimmed door cards rather than the semi solid plastic the more basic trims came with. This stuff seems to absorb muck and scrubbing gets the bulk of it  and leaves it looking nice until it dries...
Quote from: JamesV6CDX on 09 September 2025, 22:57:16
Excellent progress... good luck with the MOT :y
Ta :y
Have to say it's been incredibly therapeutic whilst trying to avoid being in the house.
Quote from: Doctor Gollum on 09 September 2025, 23:41:26
Ta :y
I can relate to that, there is little better escape than tinkering with a car, especially when the weather is nice, and you're not up against the clock.. mainly why I'm doing a little more of it :y
Been busy today...
Oil change all done. It only takes 8.5 litres. And guess who found the new sump plug washer on the floor having just refilled it and run it up to temp ::)
Managed to undo the sump plug, fit the washer and refit the plug without losing more than a cup full of oil or burning my finger :-X
Won't make that mistake again :-X
Other work was a combination of tasks, not least resealing the freshly sealed lights. Weather has finally been atrocious and inspite of the new seals, one light was flooded and tother clearly had water draining past it into the inside of the boot >:(
Stripped out the boot for several different jobs, removed the lights and bumper for 4 reasons. Reason number 1 was to remove the tailgate aperture trim which runs down behind it which needed removing to address the water ingress with a bit more vigour.
Picked up some expanding all weather roofing sealant and ran a thick bead behind the trim from the gas strut mounts to the rear panel. Hopefully this will be enough to divert the water away from the light apertures and into fresh air behind the bumper. I also ran a bead around the outside edge of the foam pads to dissuade any water that might now get behind the lights. Time will tell... :-\
Bumper removal reason number 2 was to address the beginnings of some rust on the nearside rear quarter. Turns out it's had a minor repair in the past and paint was chipping along the top edge of the bumper and eventually moisture had got to the metal. It's right on the bottom edge as it folds over the bumper, and barely an inch long... Well it was ::)
Really it could do with another small skim of filler, but I can live with the 3/4" scar. Been primed and painted and there's a scratch on the dog leg of the wheel arch, so once the colour coat has hardened over the weekend, I will rub both down with 1500 grit wet and dry and then lacquer it to blend it to the body line. A similar approach to a scratch on the OSF wing has saved the panel, so worth a go.
Bumper removal reason number 3 was to deal with the shin breaker. Now removed and replaced with a factory fold away tow bar. Just waiting on the last couple of bits of hardware to arrive to wrap that up and need to run the wiring. The wiring being reason number 2 for stripping the boot. Again...
Bumper removal reason number 4 was to investigate the non function parking sensors. Once the bumper was off, the inch of mud and other crap covering the sensor suggested it had had enough. Sensor swapped with the used one along with the relatively clean loom I acquired at the same time and I now have working parking sensors.
Today's surprises were the missing under trays and the lack of the low speed impact pad behind the rear bumper.
Oh, and the droplinks are floppy but will require cutting off to remove as they're quite crusty... and the CV boot cable tie bodge didn't hold... Need a metal one to clamp it a bit tighter. Failing that another CV shaft. If it needs removing it to fix, I may as well fit one that isn't broken.
Quote from: Doctor Gollum on 09 September 2025, 22:40:01
So far then...
2 knackered tyres
Aircon inop
Osr tail light out
Number plate lights out
Fuel gauge inop
Radio inop
Absolutely minging inside
Some cosmetic issues
Bodged wiring for said shin breaker
Interior light burnt out. Literally.
Auto lights not working (see above).
Surging at low speeds.
Stretched transfer box chain - replace chain and fluid/ possibly replace transfer case fitted with new chain
Service engine
Service gearbox
Change diff fluids
Front end vibration 65-80: tyre rebalance?
Crap headlights... New bulbs or xenon retrofit...
Today's efforts saw the tow bar installation completed along with retrofitting a reversing camera and finishing up the rear quarter paint...
Towbar and camera both function as they should and just needed a spot of coding to make them work. Unfortunately, because it's a 2007 and the folding tow bar is a later option,. there's nothing in the system that will allow me to code in the folding version. That said, it now knows it has a towbar fitted and has trailer recognition to boot. And it's vastly improved now you can walk up to the boot without losing a knee :D
Whilst I was in there, I reprogrammed the head unit as well. Bizarrely the car it came from had rear entertainment but no phone and no cd changer ??? Fortunately both are a box tick so now work as they should.
Another discovery, although not really a surprise if you stop and think about it, the auto lights sensor also performs an auto wiper function. I obviously ticked that box too and again appears to work as expected.
I need to revisit the rear quarter. The paint match is shocking and today wasn't perfect the best day for painting outside... ::)
From an upgrade perspective, leather and a heated washer bottle are about all that's left to do. Well that and the transfer case :-X
Quote from: Doctor Gollum on 15 September 2025, 23:28:29.....
I've mentioned this before ...
Lights & wipers are linked on my W166 in that the lights will turn on after the wipers have auto wiped so many times (I've not counted) even when it's not dark.
Quote from: Andy B on 16 September 2025, 08:21:04
I need to try that. If you leave the wiper switch on the first intermittent setting, when you start the engine it sweeps once regardless of the weather and it's then fully automatic. The ML does the same. But haven't noticed the behaviour you describe on TPC, either because it's seamless or because the lights are always on auto :-\
Pretty nifty if they both do that 8)
Both my cars do that. I thought it was normal on anything built in the last 10-15 years?
Mine appear to be related to how heavy it thinks the rain it - so if its bucketing down, the lights will pop on almost straight away, but if its a single wipe every 15s or so, might take a couple of minutes.  I *could* read the distructions, but that pesky Y chromosome prevents such girliness.
Migv6 le Frog Fan
Over complicated gimmickry for no sensible reason.
If people are too stupid to know when to use their wipers and lights (independently or together) they shouldnt be allowed to drive.  :)
Quote from: Migv6 le Frog Fan on 16 September 2025, 10:00:33
;D
Says the chap.with rain sensing wipers on his Omega >:D
You're correct in your point and I am pretty sure noone disagrees with the sentiment :y
Even my poverty spec grandland has this.
Diesel till I die
Yes, so it bloody well should ;D
It's at least 20 years newer than Albs' Omega >:D
Quote from: TheBoy on 16 September 2025, 09:50:16
Pretty much the same as mine .....
The handbook is far far too big to actually read, though there is a CD version loaded into the 'radio' too
It's probably in the list of mandated goodness along with TPMS and speedlimits :-\
