Author Topic: Oil in radiator header tank.  (Read 80024 times)
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
Re: Oil in radiator header tank.
« Reply #15 on: 30 September 2025, 20:29:16 »
It’s cool DG cos I’ve already done the filter conversion.
Was just curious about any issues anyone ever experienced.
I don’t need to do this job. I’m just bi-curious 🥰
RIP Paul Lovejoy
« Reply #16 on: 30 September 2025, 21:18:29 »
Had heard  >:D
Webby the Bear
  • Northampton
« Reply #17 on: 01 October 2025, 09:18:45 »
RIP Paul Lovejoy
« Reply #18 on: 01 October 2025, 14:37:08 »
Ps.. though I’ve never had to do this job I often look at those two unions above the oil filter and they just don’t look like they’d come out 🤣🤣
Anyone ever had issues with them? I suppose absolute worst case scenario you’d end up chopping the pipe above the nut and getting a 6 sided socket on it. Just wondering if anyone ever had issue?
As per above, filter off,, crows foot spanner, tighten slightly, then undo.
Never had an issue to date with them.  :y (probably done many tens of them over the years, including Opti's whilst it was on his drive!)
Webby the Bear
  • Northampton
« Reply #19 on: 01 October 2025, 15:38:15 »
Great to know, thanks Mark 👍👍👍
RIP Paul Lovejoy
« Reply #20 on: 02 October 2025, 01:32:36 »
A used, stainless cooler, is likely to be fine. You'll need to source dowty seals, coolant bridge seals, union-to-cooler seals, grey RTV, cooler-to-plate o-rings, oil filter housing seal etc. But, a stainless, used cooler will be fine.
The old style coolers (which corrode) have protrusions on the top of the cooler radiator - whereas the stainless ones are completely flat on the top edge.
Here is the old stlye, known to corrode:
Here is the newer, stainless type, flat on top:
And, food for thought - I am currently in discussion with a European firm, about a bulk buy of these:
Ultimately it's almost impossible to get a new, original cooler these days (or they are astronomically priced)... so worth at least exploring potential other options / viable alternatives :y
GrahamK
  • Shropshire
  • 2003 2.6 CDX Saloon
« Reply #21 on: 02 November 2025, 16:58:32 »
Hi all,
Continuing with this thread that I started a little while ago.
I have not found a UK source for an oil cooler and so today I have removed a cooler from a spare 3.2 engine I have. By definition, a late engine, surely.
Looking back at the pictures posted by James my replacement one looks rather like the older type. It does look S/S though. The GM part number on it is 90572067.
Without any other tenable solutions, I am planning to re-use it, for now.
Looking at the parts I have on the bench I wonder if someone would be kind enough to error check my thinking here: -
Firstly, I have the banjo bolts that secure the metal pipes to the top of the cooler. These have what looks like an aluminium washer above and below the banjo. These are available, but could I re-use these?
Next, I have the pair of "O" rings that seal the cooler against the bottom of the cover plate. These are circa 28mm diameter but are totally flattened. I have no idea about part numbers for these, or if I could use a suitably sized O ring from a multi part (generally pretty cheap) set.
I have some Vauxhall grey sealant.  I can also see from the exploded parts catalogue view that there is thread lock used somewhere in this assembly. Does anyone know where?
Finally, I have what I think are Dowty washers securing the Banjo bolts that go through the coolant bridge. One above and one below, so I need four here again. These are buggered.
Measuring them, they are 23.85 mm OD, 1.6mm thick and approx 16mm ID. It is difficult to tell as they are pretty ragged. The diameter of the banjo bolt is 15.8mm OD, near the shoulder, under the bolt head. I'd have thought that the rubber part of the washer should be a little less than the diameter it is sealing against, but I've not specced any of these before. Any idea which ones to order?
Any other tips or advice would be much appreciated.
Regards,
Graham.
« Reply #22 on: 02 November 2025, 17:59:54 »
Those flat 'seals' are the dowty washers.
« Reply #23 on: 03 November 2025, 10:28:14 »
I would try to source dowty washers if possible, in my experience reusing old ones does tend to leak, particularly if the old ones are original.
GrahamK
  • Shropshire
« Reply #24 on: 03 November 2025, 10:42:13 »
Measuring the flat steel washers with the captive rubber/nitrile inner (these are the Dowty washers, yes?) and comparing the size I have with suppliers tables means they are most likely M16.
The rubber only rubber rings that look exactly like flattened O rings I do not have a part number for. (they came with the oil cooler apparently)
I'm not sure if it is a specialist seal, but considering where it is, if I take a gamble and the bloody thing leaks, I'm back where I started.
I note what Doc said about the flat rubber seal being a Dowty washer. Is that a different type of Dowty washer, or are we just lost in translation.
Any help much appreciated!
« Reply #25 on: 03 November 2025, 10:47:35 »
Correct
Valentin
  • France
    • '96 MV6
« Reply #26 on: 04 November 2025, 10:01:02 »
There is a solution like I said before, the part made by ACS in Ukraine is perfect. It's a bit expensive but looking at the amount of work it needs to be replaced, better to go for this aftermarket solution IMO. AND it comes with the 2 O-rings that you found flattened. They actually are O-rings and made in NBR, same material as any o-ring made for automotive industry  :y
https://acsparts.biz/en/maslookholodzhuvach-90412391-opel-saab.-nerzhaviiucha-stal/
https://www.omegaowners.com/forum/index.php?topic=151703.msg2058124#msg2058124
As for the dowty washers for the coolant bridge banjos, again, take the old one and a banjo bolt with you and go to a truck repair shop. They can find a model that is close to yours. Never reuse the old ones.
For the all metallic washers on the oil banjos, same you can ask the truck shop. In my case they gave me 4 new ones but arrived at home I found out one of them was a bit smaller and didn't fit. I reused an old one after a good clean and 400 sandpaper. It works fine.
Grey OEM Vauxhall/Opel sealant or ELRING DIRKO 70ml GREY Gasket Sealant for the plate.
Finally, to have peace of mind about any leaks, I put a very thin layer of Loctite 5923 on each face of the 8 washers and on both contact faces of the 2 O-rings. Don't put too much on those for the coolant bridge, because they need to make electrical contact for the temp sensor's ground. No RTV, only suitable Loctite 5923 which is a permanent sticky/soft mixture that never falls and never tears apart.
Take care of the peripheral components (wiring looms, tubes, connectors) and everything should be fine :y 8)
« Last Edit: 04 November 2025, 10:11:53 by Valentin »
