Author Topic: Pollen filter box / housing removal  (Read 13052 times)
JamieC2311
  • Northern Ireland
    • Omega MV6
« on: 13 December 2025, 05:33:33 »
Has anyone ever removed the housing for the pollen filter? Is it done from the engine bay side or up behind the dash? If it has to be from behind the dash I presume its a pig of a job :-*
RallyArde
  • Finland
    • Omega B2 2.2 16v
Re: Pollen filter box / housing removal
« Reply #1 on: 13 December 2025, 09:52:32 »
Though the engine bay by removing the scuttle partially and you should gain access to the cabin filter ;)
Omega - when bad camber is actually a good camber
JamieC2311
  • Northern Ireland
    • Omega MV6
« Reply #2 on: 13 December 2025, 21:11:13 »
Yea i want to remove everything though to paint the engine bay
« Reply #3 on: 14 December 2025, 09:14:43 »
Haynes may well cover it if you can't find the guide here :y
RallyArde
  • Finland
    • Omega B2 2.2 16v
« Reply #4 on: 14 December 2025, 09:25:31 »
What I meant was that you can remove the filter from engine bay side by taking off the scuttle partially, thatīs how I did it in my Omega. So you donīt need to remove dahsboard or anything inside the cabin.
« Reply #5 on: 14 December 2025, 14:24:10 »
I think the OP is asking how to remove all the plastic mounts and ducting through the bulkhead....
YZ250
  • Oxford/Bucks border
    • Black 3.2 Elite Estate
« Reply #6 on: 14 December 2025, 22:39:17 »
Can’t see anything in Haynes but from the drawings it looks like the pollen filter housing drops in from above, with the three fixing nuts likely to be up behind the glovebox on the inside.  :-\
« Reply #7 on: 15 December 2025, 15:30:06 »
Glovebox, fan and airbag removal will strip away most of the passenger dash allowing significantly improved access to visualise and strip the interior parts of the cabin air intake ;)
It will also give an unfiltered view of the areas that rot away unnoticed where the firewall and scuttle join the shell.
JamieC2311
  • Northern Ireland
    • Omega MV6
« Reply #8 on: 16 December 2025, 04:02:06 »
I found this one for sale on ebay, it doesnt seem to have the 3 fixing nuts as in the original diagram. Hopefully theres 2 bolts on the engine bay side where the top lugs are and it can split from the rest  :y ???
Thanks for the tips and advice, will have a go at it tomorrow & will report back if & when its out! Its nice to still have a forum thats still pretty active & plenty of help, any others i was on years ago slowly but surely died a death a long time ago ???
JamieC2311
  • Northern Ireland
    • Omega MV6
« Reply #9 on: 16 December 2025, 04:24:24 »
Possibly bolting into these 2 points on the air con unit?
« Reply #10 on: 16 December 2025, 10:16:35 »
The air intake connects to the side of the heater box. That image shows the top of it. ;)
JamieC2311
  • Northern Ireland
    • Omega MV6
« Reply #11 on: 16 December 2025, 14:56:55 »
Just had a look and the nuts are definitely in behind the passenger side dash ;(
« Reply #12 on: 16 December 2025, 16:14:26 »
Once you've stripped everything off the dash, it's only a handful of nuts to remove the dash pad. It was fitted assembled, removing it is far from impossible.
The hardest part is getting the end vent assemblies dismantled.
The passenger ends vent, glovebox and passenger airbag should give you all the access you require.
Migv6 le Frog Fan
  • Essex / Suffolk border.
    • 3.2 Elite. Nissan Leaf.
« Reply #13 on: 16 December 2025, 19:59:24 »
Question is, why would you want to remove it ?
« Reply #14 on: 16 December 2025, 22:37:32 »
To try and save whatever is left of the bulkhead :-\
