Author Topic: Part number help wanted: Fr coil spring  (Read 15413 times)
JohnM
  • Newark on Trent
    • 2.5M Estate
Re: Part number help wanted: Fr coil spring
« Reply #15 on: 12 January 2026, 14:40:10 »
And as Doctor Gollum says, the Thrust Angle (might be called something else on non-Hunter machines) absolutely must be 0'00, nothing else.
« Reply #16 on: 13 January 2026, 09:56:13 »
Even if you don't refresh the rear suspension, you would be well advised to replace the rear track rods as they have a nasty habit of seizing solid.
« Reply #17 on: 15 January 2026, 08:58:45 »
I only ever bothered if they needed adjusting, and heat couldn't free them.  Obviously when fitting new, a good coating of (proper) coppaslip on the threads tends to prevent further reoccurance.
« Reply #18 on: 15 January 2026, 12:10:29 »
Have had a few that bent trying to free off... One was on the ramp at WIM.
 Without seeing or knowing the car or it's history the advice would be to replace them.
grifter
  • Paisley, Scotland
    • Omega 2.6 CD / Elite 3.2
« Reply #19 on: 18 January 2026, 21:56:42 »
Anytime I'm under the motor (maybe every few Months) I give all the adjusters bits a scoosh of loose oil, then when it comes to needing to remove/adjust a track rod it's (usually) easier to move.
I fitted the pedders top mounts to the omega when I refurb'd the front end, tightens it up quite nicely without being too harsh.
https://pedders.co.uk/details/5851
JohnM
  • Newark on Trent
    • 2.5M Estate
« Reply #20 on: 13 February 2026, 22:19:49 »
A belated thanks to all, esp. the Dr and Jamie.
Took a while but all parts came and duly fitted.  Aligment done on Wednesday and drives well.
I am going back for a tweak next week as the steering wheel is a bit off and I rather like it perfectly straight.
Looks llike I'm keeping her, so back with more niggles to resolve in due course.
