Another MOT pass
Started by Lizzie Zoom, 28 January 2026, 17:26:49
Varche
 ;D keep filling sandbags.
See you in twelve months to compare notes
Quote from: dave the builder on 03 February 2026, 11:28:44
just stick to the IMPORTANT JOBS , like a new 'magic tree' air freshener for the windscreen  ;)
Oi!  >:(
;D
Quote from: TheBoy on 04 February 2026, 09:35:50
Oi!  >:(
;D
New magic tree? Wouldn't you just reinstate the one you took off on the way to the test? :-X
Quote from: Kevin Wood on 05 February 2026, 14:52:18
Oi!  >:(
;D
That's what any sensible person would do, surely?
Diesel till I die
Lizzie Zoom
#94
Sorry to be a pain, but please excuse me as an older women asking this:  I have purchased a can  of Holts professional brake cleaner, which I will use as instructed on the callipers and pipes. But can this be used to get the grime and any rust off of the shocks? ::) ::)
I note all your comments about using a "damp cloth", but wouldn't a cleaning agent assist the process as I use cleaning products to remove grime and grease from items like the cooker around the home? ??? ???
Why are the shocks apparently so vulnerable to heavier type cleaning?  I do recognise though that the "bellows" / rubber parts must not come into contact with any cleaning products, so would mask them off.
Thanks for any replies and assistance with my work plan building for later in the year :D ;)
I think brake cleaner would be overkill. Just a bit of soapy water would be fine, then see if any misting returns.
YZ250
Oi!  >:(
;D
My wife has an Angel dangling from her rear view mirror. If we forget to remove it before the MOT, it's always on the passenger seat when we collect her car. This is decent of them really, as I suppose they could be petty and fail it.  ::)
YZ250
Quote from: Lizzie Zoom on 05 February 2026, 15:18:44
Brake cleaner's main attraction is that it dries/evaporates in seconds, which is handy when you want to clean and paint brake calipers. It's not really necessary for shocks and other parts to be dry in an instant so soapy water is fine.  :y
In my view, brake calipers are either painted and shiny, and with decals, like mine  ::) ;D , or grubby and ordinary. To answer your question that you asked somewhere regarding painting them, I've used Foliatec Brems and E-Tech caliper paint with good results. I have only ever needed to paint them once, and my Omega calipers painted with Foliatec, and with decals, were still nice and shiny fifteen years later when I sold it.  :y
If you choose  Foliatec, do not follow the instructions to mix enough to paint all four calipers. Mix enough paint and lacquer to do one caliper and then repeat for each caliper. If you follow their instructions, the paint will be bullet hard in the pot before you've finished caliper number two.  ::)
E-Tech is more forgiving as there is no mixing involved.
It's only mud and crud from the road covering your shocks Lizzie, as said by others warm soapy water will be more than adequate.  :y
Whenever I wash the car with a jet wash, I always give everything under the wheel arch a blast to get rid of the crud. If you do that though, be a little careful around the airpipe.  :)
Lizzie Zoom
Thanks Sir Tigger, YZ250 and Kevin for that reassurance and advice :y  :y
In regards to paint for the callipers YZ250, I have purchased a can of Jenolite "Original Brake Caliper Paint" which is "high gloss durable finish" in silver :D
Are you a Virgo?
I ask because you're overthinking this to a whole new level :o
100 replies and counting on how to ignore MOT advisories and wipe down a pair of shocks.
Diesel till I die
ronnyd
Quote from: STEMO on 05 February 2026, 20:14:27
;D ;D
Lizzie Zoom
Quote from: Doctor Gollum on 05 February 2026, 19:53:27
Are you a Virgo?
It is because I need to know what is required before I start any work.  Others have raised many valid points on this thread, which is great as I could have just cleaned down the shocks with a cleaning agent as I would in my home! :D :D ;)
Lizzie Zoom
Yeah, isn't still good on the OOF Steve!! >:D >:D ;)
Like the "Word Association" thread..................................................!!!!! >:D >:D >:D :P
