Author Topic: Xeon head lights  (Read 22476 times)
Omega Nige
  • Oxfordshire
    • Omega 3.2 V6 Elite
Xeon head lights
« on: 08 September 2026, 16:09:49 »
Hi,
I am looking to replace the switches front and rear for the levelling of the Xeon lights. Does anyone know where I can get the switches or the part numbers for them?
Thank you  :)
Re: Xeon head lights
« Reply #1 on: 08 September 2026, 22:58:28 »
You might find half decent second hand ones, but they were obselete a decade ago.
Pre facelift Vectra C ones can be adapted but anything from '55 onwards won't work as the facelift cars are CanBus based.
Omega Nige
  • Oxfordshire
« Reply #2 on: 14 September 2026, 11:54:33 »
Thank you.
Can the level system be converted to the levelling thumb wheel on the Omega's with out Xeon lamps?
« Reply #3 on: 14 September 2026, 12:02:05 »
What are you trying to achieve?
If you're retrofitting xenons, then yes you simply swap the adjuster motors from your existing halogen headlights and the thumb wheel will work.
However if you already have factory fitted xenons,.the levelling is controlled by an independent ECU and the car simply isn't wired to add on the manual control.
Omega Nige
  • Oxfordshire
« Reply #4 on: 16 September 2026, 09:48:18 »
Hi,
Thanks, I did mean that I have Xeon light and wanted them to work with the thumb wheel! Looks like Ill have to either mend the switches I have or find replacements.
Thank you for your help  :)
cam.in.head
  • West yorkshire
    • omega cdx 2.6 auto
« Reply #5 on: 16 September 2026, 10:54:12 »
there is a brand new level  sensor on ebay at the moment but youd gave to check the part numbers as it may not be for the headlamps ???
Omega Nige
  • Oxfordshire
« Reply #6 on: 03 October 2026, 12:31:32 »
Hi, which level switch does the headlights? Their are two, one on the front near side and the other on the rear off side?
 Thanks 😊
« Reply #7 on: 03 October 2026, 13:45:01 »
Rear nearside.
Right hand rear is the rear suspension level sensor. Totally different as it's effectively the ECU for the suspension and is independent of the lights.
