Author Topic: I feel like an idiot  (Read 1904 times)
Cumbria
  • Southport. Merseyside.
« on: 22 September 2008, 11:22:54 »
Car wouldnt start this morning turned over ok but no spark. Phoned AA they came out tried it & it started first time. AA said if it happens again lock door with remote leave a few minutes open door with remote & try again & it should reset itself. Could be worth bearing in mind if any other members have the same problem.
Re: I feel like an idiot
« Reply #1 on: 22 September 2008, 11:24:36 »
Can't really see what locking it would do. The immobiliser on the Omega is separate to the alarm / central locking as it uses its' own transponder. Can you recall if the EML was flashing when you had starting problems?
« Reply #2 on: 22 September 2008, 11:28:02 »
Stick a paperclip up its diag port, and post back results....
...AA man is not familiar with these cars, and has told you rubbish.
As to feeling an idiot, welcome to my world ;D
Cumbria
« Reply #3 on: 22 September 2008, 11:28:53 »
No EML was not flashing. Just stayes lit like hand brake lite.
« Reply #4 on: 22 September 2008, 11:33:43 »
Paperclip it.  I reckon you'll find a nice, naughty 19 stored....
Gaffers
  • NE Hampshire/Surrey
    • Ford Ranger Wildtrak
« Reply #5 on: 22 September 2008, 12:37:45 »
...I often feel like an idiot.......but then I see sense and go for the egg fried rice  :D :D :D
« Last Edit: 22 September 2008, 12:38:25 by mrgaffney »
« Reply #6 on: 22 September 2008, 12:48:56 »
My advice would be, next time it does not start call the AA man, stick the key up his arse and then re-try.
It wont solve the non-start issue but will stop the AA man telling you to do unrelated things!
« Reply #7 on: 22 September 2008, 12:57:49 »
If the key doesn't solve it, try one of the plug leads.  ;D
mantahatch
« Reply #8 on: 22 September 2008, 13:24:02 »
In the defense of the AA if I may, when he arrives and the car is running, it is a nice easy quick fix for his figures, they are driven by figures like many other businesses.
Yes he could have spent some time checking the codes, but this fix would have got him a good "fix time"
There are some good, average and bad one's.
Mike
« Reply #9 on: 22 September 2008, 13:26:52 »
Mike
Not possible to defend somebody who says to do something which will not have any effect.
He should have said 'it will need the ECU reading to check for stored fault codes'...........
« Reply #10 on: 22 September 2008, 13:29:58 »
You wake me up from my deepest sleep ;D ;D
ps: today I also feel a bit idiot..a code job waiting from 3 months still waiting there ;D
