Pages: 1 [2] 3  All   Go Down
Author Topic: Here We Go Again - Computer Related  (Read 2975 times)
Re: Here We Go Again - Computer Related
« Reply #15 on: 23 September 2008, 19:09:27 »
If you need that level of cooling:
a) Look at BTX cases, rather than ATX
b) You're doing something very wrong in the build.
willyboy
  • Leeds. West Yorks
  • Can Do !!
« Reply #16 on: 23 September 2008, 19:12:24 »
I bought an Antec  really like it  see pic
http://www.overclockers.co.uk/showproduct.php?prodid=CA-065-AN
into gaming hence the case
« Reply #17 on: 23 September 2008, 19:14:19 »
Sorry, hate it.
Can't see the point in a rather window in to PC?  And I have this advertion to blue LEDs, due to being straight....
willyboy
  • Leeds. West Yorks
  • Can Do !!
« Reply #18 on: 23 September 2008, 19:21:54 »
LOL
 PC is on floor on my left dont even see it but it is handy to check if somat not right have quick look ...LED's all can be turned off :y
I must be gay :D
« Last Edit: 23 September 2008, 19:22:28 by willyboy »
  • Online Online
« Reply #19 on: 23 September 2008, 20:56:25 »
I dont actually know that I will need that level of cooling, I am just planning ahead and planning for the ammount of heat that may come off future motherboards and then if I max the case with hard drives then I would rather have 6 redundant fans doing noting than 1 than cant do enough.
« Reply #20 on: 23 September 2008, 20:59:53 »
Its likely that power requirements will drop, or stay static, as energy efficiency is a big think at the moment...
The current range of SPARC chips we're using at work are pretty impressive from an efficiency point of view...
  • Online Online
« Reply #21 on: 23 September 2008, 21:53:37 »
    *  Features  Support to 11 5.25’’ drive bays
    * Relocate-able front control panel (Power, Reset switch, HDD & PWR LEDs)
    * Support up to Extend ATX & BTX
    * Ventilation opening on top ( 62% opening ratio)
    * Built-in 5.25’’ drive bay accessory box
    * High efficiency ventilation: Dual 12cm silent fans in front & rear, 9cm fans in rear and top, 25cm fan on side
    * Retractable foot stand
    * 25cm fan on the side panel benefits CPU and GPU temperature and reinforces system stability.
http://www.aria.co.uk/Products/Components/Cases/MIDI+Tower/Thermaltake+Armor+-+Silver%2C+Window+Side+Panel+?productId=26554
Not in silver though, would have to be black. :y
« Reply #22 on: 23 September 2008, 21:59:42 »
a bit chavvy.  and overkill.
many of these cases have all those unnecessary features, simply not required.
What mobo supports more than 6 hdds anyway?
  • Online Online
« Reply #23 on: 23 September 2008, 22:05:36 »
Both of my Gigabyte boards have support for 2 ide and 8 sata
« Reply #24 on: 23 September 2008, 22:11:32 »
And you plan on using all of them? Performance will be rubbish, bet they are all hanging off the same PCI device - baseline specs are all to easy to follow, but you need to look more at the implementation...
Plomien
  • Swansea
    • Landrover Freelander TD4
« Reply #25 on: 23 September 2008, 22:19:35 »
I have the Thermaltake Armour case and its fantastic for cooling, plenty of HDD space as well and can easily be converted to watercooling
http://thermaltakeusa.com/Product.aspx?C=1277&ID=1405
also had a friend add some blue Leds to the side fan for me for that nice blue glow :D
  • Online Online
« Reply #26 on: 23 September 2008, 22:20:20 »
Time will tell.
My old XP 2100 has 5 drives bolted into and a dvd drive and performs merrily, all IDE at that.
« Reply #27 on: 23 September 2008, 22:23:53 »
Time will tell.
Many IDE implementations will be on 2 PCI devices - 2 in Southbridge, and up to 4 on a seperate IDE chip, which Promise being popular on cheap boards.
SATA is usually done on a single chip, connected to a sinlge PCI device on cheap boards (better boards hang them off x4 PCIe channels)
  • Online Online
« Reply #28 on: 23 September 2008, 22:26:41 »
What board and case do you recomend?
« Reply #29 on: 24 September 2008, 10:33:32 »
Whatever you do, don't buy one of those gay PC cases with windows in the side if you live anywhere near a radio amateur. Their EMC performance is woeful. Get a proper metal box. Nothing to see inside a PC. >:(
Pages: 1 [2] 3  All   Go Up
