Author Topic: back to WIM on Saturday..  (Read 1391 times)
« on: 25 September 2008, 15:28:32 »
They did a top job on the alignment, but i forgot to ask them to ballance the wheels.
80+ through to 90, i get vibration through the seat, slow down below 80 and it goes away...
I suspect rear ballencing is off...
So rang them up, they said i can pop down on Saturday and pop them on the machine to check them  :)
Re: back to WIM on Saturday..
« Reply #1 on: 25 September 2008, 15:33:41 »
I'm over the moon with the job they did on my alignment! I still have a slight pull but am putting that down to the uneven tyre wear. Tony has said that if it's still there after I have the tyres changed I can pop back :y :y :y
« Reply #2 on: 25 September 2008, 15:54:47 »
I have the same problem as Tunnie, they dont seem too bad, but there is still a vibration that starts arround the same speed.  ::)
Just wish they had a WIM in the South Yorkshire area.  :-/ :-/
« Reply #3 on: 25 September 2008, 16:02:59 »
Brackley to WIM just to balance a couple of wheels  :o
ffcgary1
  • Mitcham,Surrey.
    • Omega Estate/ jaguar XJ6
« Reply #4 on: 25 September 2008, 16:13:21 »
 Hotel 21's trip from scotland, NOW that was a trip to WIM, BRACKLEY? nothing to it. :D
Jaguar XJ6
« Reply #5 on: 25 September 2008, 16:34:34 »
Yep...
I could use a local monkey firm, BUT if i go to WIM, i know its done right!
just under 40 miles each way, its an easy drive.
« Reply #6 on: 25 September 2008, 16:36:34 »
For geometry I would definately agree go to Wim - but any decent tyre outfit should be able to balance a wheel  :-/
You're right though - if they're prepared to do it and you're that close....... :y
« Reply #7 on: 25 September 2008, 17:14:09 »
To be fair last time i had it done, was at Vauxhall, and the vibration went, but its been slowly comming back.
There are a couple of local places, but i am prepared to drive there for a job i know is done right.
Its quite a nice drive too!
« Reply #8 on: 25 September 2008, 17:27:27 »
Would be tempted to find out if the wheel was deformed in any way.  Dont know how accurately they can tell with the tyre on.  Might be worth the extra to remove and refit tyre and double check everything for the sake of an 80 mile trip.  :y
« Reply #9 on: 25 September 2008, 17:33:05 »
Hopefully tony will be there....
Father tunnies had 4 new tyres on when he was at WIM, his is smooth at 100+ (on track) mine is smooth until 80.
very minor vibration through the wheel, mainly the seat.
I will report back how it goes  :y
« Last Edit: 25 September 2008, 17:33:22 by tunnie »
Taxi_Driver
« Reply #10 on: 25 September 2008, 18:19:00 »
I suspect thats a buckled wheel tunnie......balancing vibration usually occurs at less speed.....Ive had that before at 80mph.....vibration.....was a buckled back wheel.....luckily it was on my VeccyC (steel wheels) so was only £40 for a new steel from vx.
« Reply #11 on: 25 September 2008, 19:10:35 »
some outfits seem to struggle to balance omega wheels...
