Author Topic: Omega CVT...  (Read 4706 times)
Markjay
  • London
Omega CVT...
« on: 12 December 2006, 20:52:31 »
TB updated the ECUs on my car, including the autobox one.
Suffice to say that I am no longer contemplating an ATF change…. the box shifts VERY smoothly, the ‘kick and klong’ when shifting-up disappeared completely, and the shift-down with kick-down is immediate and with no noticeable delay. In short, the transmission is now very civilised, fast, and smooth.
Interestingly, when I first noticed that the transmission was rough and ‘kicking’ on shift-ups, I asked Vx to check it. The ‘couldn’t fault it’ and said they checked the fluid level and all was OK. They either never heard of firmware upgrades, Tech2, or TIS, or just couldn’t be bothered to do anything about it…
So in short the autobox ECU update made a huge difference, highly recommended to anyone with an autobox.
What I forgot to do on the way back from Bletchley was to check how the transmission behaves in ‘Sports’ mode, in the past I found that the car was changing gears very violently when in this mode so I just stopped using it. I have a long drive tomorrow to Suffolk so will try it and report back…
As expected, the engine ECU update did not produce any noticeable improvement, though I will compare the mpg statistics to see if there is a difference there.
Thanks TB!
Alas, no more Omegas....
Re: Omega CVT...
« Reply #1 on: 12 December 2006, 20:57:44 »
Similar to my experiences then :)
Markjay's 821 ECU was taken from V3 to V8 (eventually - the radio needs to be on to program ECU, else it fails part way through ::))
Lawman
  • Cleland
Re: Omega CVT...
« Reply #2 on: 12 December 2006, 21:00:46 »
Markjay's 821 ECU was taken from V3 to V8 (eventually - [size=14]the radio needs to be on to program ECU[/size], else it fails part way through ::))
Well it is usually a Vauxhall technician that would carry out the programming ::)
Re: Omega CVT...
« Reply #3 on: 12 December 2006, 21:02:51 »
Probably as it has a part CAN implementation, probably find the radio is the i/o bridge between 2 buses or something daft.  Wonder what happens if its a 3rd party stereo?
Lawman
  • Cleland
Re: Omega CVT...
« Reply #4 on: 12 December 2006, 21:05:58 »
Valid point! That could have you chasing your tail for hours :-/
Markjay
  • London
Re: Omega CVT...
« Reply #5 on: 12 December 2006, 21:25:28 »
The stereo kept getting switched-on by itself during the update, and we kept switching it off... and the update kept failing. Finally we decided that we do not touch anything while the programming in taking place, and it worked...  :y
Bo Bo
  • Coventry
Re: Omega CVT...
« Reply #6 on: 12 December 2006, 22:31:12 »
Shame mine's too old  :( or I'd be down the A423 like a shot!
Bo Bo
  • Coventry
Re: Omega CVT...
« Reply #7 on: 12 December 2006, 22:33:59 »
& probably quicker coming back  :o
Markjay
  • London
Re: Omega CVT...
« Reply #8 on: 12 December 2006, 23:48:19 »
Since my last post I had a chance to give the Sports mode a quick go. It is still not my cup of tea but it is much much better now - it finally feels like driving a car, before it was more like a rodeo ride... I will give the Sports mode another chance tomorrow during the long drive to Suffolk before passing final judgement.
The car is now much better than it was when I first bought it 5 years ago...
« Last Edit: 12 December 2006, 23:48:33 by markjay »
Markjay
  • London
Re: Omega CVT...
« Reply #9 on: 12 December 2006, 23:49:39 »
PS - Bo Bo, I like your new avatar, is this you in the picture? Funny, for some reason I thought you were a bloke. Not that I mind...  ;D
Re: Omega CVT...
« Reply #10 on: 13 December 2006, 08:34:25 »
I dont know.....I hate to say I told you so (on the autobox software update to all on here) but, I told you so....
Big Rod
  • Fife, Scotland
Re: Omega CVT...
« Reply #11 on: 13 December 2006, 10:51:33 »
So what version's mine likely to be then Mark? '02 plate 3.2.
Is it worth me doing the upgrade?
If I have to explain you won't understand!
Markjay
  • London
Re: Omega CVT...
« Reply #12 on: 13 December 2006, 10:56:42 »
Anywhere between v3 which is what I had on my 2001 and v8 on AA's 2002... and yes, if you don't have v8 yet then it is absolutly worth it!
Big Rod
  • Fife, Scotland
Re: Omega CVT...
« Reply #13 on: 13 December 2006, 11:09:25 »
How do I find out what version I have?
nixoro
  • Hitchin, Herts
Re: Omega CVT...
« Reply #14 on: 13 December 2006, 12:29:36 »
My guess is via tech2 not sure if the equivalents will tell you your ecu version.
I'm sure Theboy will be able to confirm :y
