Author Topic: Computer Help  (Read 1477 times)
Computer Help
« on: 01 October 2008, 17:44:33 »
Does anyone know of a program or a way that I can syncronise a main computer with 1 central folder with the same named folder that is added to a network.
Say I set My Documents on computer 001  and then have 4 laptops that hook up to it dailly that upload/download till all files are duplicated.
TIA  :y
Re: Computer Help
« Reply #1 on: 01 October 2008, 17:45:41 »
just nominate a PC & folder, and create a mapped drive to that folder from the other machines?
« Last Edit: 01 October 2008, 17:45:54 by tunnie »
Re: Computer Help
« Reply #2 on: 01 October 2008, 18:37:23 »
yep..
easy approach is to define same username with same password with admin rights in all pc and laptops..
for xp related subject heading "How to configure file sharing in windows XP"
http://support.microsoft.com/kb/304040
for vista
http://technet.microsoft.com/en-us/library/bb727037.aspx
and if you still have problems play with firewall settings to see this effect or not..
also you can search the other pc s with their IP
from the command line ipconfig -all will show ip numbers.. :y
ps  or from the explorer adress line write the ipnumber\c$
« Last Edit: 01 October 2008, 18:39:47 by cem_devecioglu »
Bandit127
Re: Computer Help
« Reply #3 on: 01 October 2008, 18:46:52 »
There is another way and that's Offline Files.
Clicky
I don't fully understand it but I think it will do the job for you and works seamlessly.
Re: Computer Help
« Reply #4 on: 01 October 2008, 19:04:42 »
Yup, offline files is official way...
Re: Computer Help
« Reply #5 on: 01 October 2008, 21:27:05 »
Cheers everyone.   :y :y :y :y :y
graham131
  • CV13 Stoke Golding
Re: Computer Help
« Reply #6 on: 06 October 2008, 17:51:32 »
You could also try a comercial option - i use something called easy2sync and easy2sync4outlook - they are great and have never let me down.
I sync about 3 PC's, a server, 2 laptops and a NAS type drive
Cheers
Plomien
  • Swansea
    • Landrover Freelander TD4
Re: Computer Help
« Reply #7 on: 06 October 2008, 18:41:25 »
http://www.giveawayoftheday.com/sync-now/
free today only from www.giveawayoftheday.com
Sync folders and back up files.
Posted: 06 Oct 2008 02:00 AM CDT
Sync Now! is a high performance file sync product helps you to keep your files in sync between local/network folders.
Features:
Never lose your emails, photos, MP3s, documents, etc. Sync Now! combines bulletproof reliability with an extremely easy to use interface to compare, synchronize, and backup your emails, contacts, photos, iTunes, MP3s, and other important files to local directory/USB disk/Network drive/laptops…etc
Sync your files in Realtime! The realtime sync is a newly designed feature in Sync Now! It’s fast and very reliable. Your can see your files are being synced as soon as you save them!
Make sure your files were synchronized 100% successfully by our unique Byte to byte verification
Automation. Sync Now! has an easy to use build-in scheduler. You set it and forget it, just focus on your own jobs. Your financial documents, work files, emails, contacts, photos, MP3s, and other data will be synchronized and backed-up automatically. You can also use your favorite scheduler to automate the sync.
Intuitive side by side folder comparison.
Re: Computer Help
« Reply #8 on: 06 October 2008, 19:57:51 »
Cheers Plomien, will check that out at the weekend. :y :y :y
Plomien
  • Swansea
Re: Computer Help
« Reply #9 on: 06 October 2008, 20:37:20 »
you need to download and install it today otherwise the free license is no good
graham131
Re: Computer Help
« Reply #10 on: 06 October 2008, 20:41:53 »
Good site - thanks for the heads up
