Author Topic: cracked wheel nut  (Read 1114 times)
omegaman2
  • Kilsyth, Glasgow G65
  • cruise , tints, shinbuster,advanced drinking test
cracked wheel nut
« on: 03 October 2008, 12:57:14 »
the unlocking  bolt has developed a crack down the outer case  can i get a new one from he dealers ihave locking nut number :question
dieseldonicely
Re: cracked wheel nut
« Reply #1 on: 03 October 2008, 13:37:20 »
I would be disapointed in the dealers if they cant supply you wirh a new one.
Give them a ring.
« Reply #2 on: 03 October 2008, 16:27:15 »
Do you mean the unlocking 'socket' or the wheel nut with the locking holes? :-/ :-/
Either way I reckon it will be easier to get a new security bolt set complete. :D ;)
« Last Edit: 03 October 2008, 16:27:39 by Lizzie_Zoom »
omegaman2
« Reply #3 on: 03 October 2008, 17:30:52 »
unlocking socket
dieseldonicely
« Reply #4 on: 03 October 2008, 17:33:30 »
unlocking socket
Will it still remove the nuts OK? If so I would carefully remove each locking nut and replace with the normal plain nut (should be in a box with the locking socket) in case you end up stranded.
Buying an aftermarket locking nut set is probably the best (and likely cheapest) option. Unless you could get the crack welded up ?
LaserLance
  • medway towns
  • Red or Black please!!!!!!!
« Reply #5 on: 03 October 2008, 18:15:31 »
the socket's are very soft i split mine when i had a punture trying to get tyre off ,the monkeys in tyre fitting centre must have gunned up the lockers ,now i keep me lockers off if i need to go to fitters and put them back on meself and tighten up just enough (£25 a set from stealers)
omegaman2
« Reply #6 on: 06 October 2008, 20:49:05 »
vx dont have a master to fit mine so its £30.00 for a new key
its cheaper to buy a brand new set
psd off >:(
dieseldonicely
