Author Topic: Computer Question - Hard Drive Formating  (Read 1523 times)
« on: 08 October 2008, 17:47:42 »
Windows XP Pro
Cluster Size = What's the smallest cluster size a drive can be formatted to and do the cluster option alter as the partition size is made bigger?
TIA.  :y
Bandit127
Re: Computer Question - Hard Drive Formating
« Reply #1 on: 08 October 2008, 18:27:48 »
I would leave XP to decide.
But there is an article here:
The Default Cluster Size for the NTFS and FAT File Systems - clicky
« Reply #2 on: 08 October 2008, 18:38:33 »
big cluster sizes tends to waste hard disk space but if you are using large chunks of data it will improve performance :y
« Reply #3 on: 08 October 2008, 18:40:02 »
Hence the reason for this thread  :y
« Reply #4 on: 08 October 2008, 18:43:52 »
mostly I use default but for sql servers I use the biggest size for ntfs..
« Reply #5 on: 08 October 2008, 19:07:55 »
to be honest, the wasted space will be minimal, unless you are storing thousands of very small (few bytes) fews. Which you aren't.
« Reply #6 on: 08 October 2008, 19:11:37 »
yep..this was important when hd's were very expensive and small..
gwa
  • Peterborough
  • Ginger With Attitude
« Reply #7 on: 08 October 2008, 19:59:51 »
Windows XP Pro
TIA.  :y
Not sure why you are asking; but if I had a 160gb HDD I'd format 120 (minimum) for drive C: and the operating system plus programs (Office etc). Drive D: would be for data only. I would set 'Restore Points' on drive C: before any changes and only backup drive D:. If you have loads of images or music maybe modify slightly, but you should always back those up to CD or DVD.
HTH  :y
If it ain't fun, it ain't worth doin
« Reply #8 on: 08 October 2008, 20:25:10 »
Files sizes range from 10kb minum varying in size up from that, genally not normally over 750kb.
« Last Edit: 08 October 2008, 20:25:25 by skruntie »
« Reply #9 on: 08 October 2008, 20:34:23 »
Windows XP Pro
TIA.  :y
HTH  :y
Smallest drive I use is a 200GB.  I generally Split 25GB for System.  25GB for office and program install.  I run a 50GB temp Partition and move the nternet temp foler and others like to that drive.
The last partition I move my Documents to it.  Experience has proved to me than when a drive/Windows goes tits up then files on that partition (System/Window) get distorted.  With them moved they have a better chance of survivng.    :y
There was a thread at the begining of the week regards a laptop.  Had My Documents been on Drive D, then any stored work would have been safe.  System corrupt, format C:  Re-install, Move My Doments to D: and carry on where you left off.  ;)
« Last Edit: 08 October 2008, 20:35:02 by skruntie »
gwa
  • Peterborough
« Reply #10 on: 08 October 2008, 20:42:53 »
Windows XP Pro
TIA.  :y
HTH  :y
If only we lived in a perfect world like Microsoft  ;D
« Reply #11 on: 08 October 2008, 21:01:03 »
So even 4kb clusters aren't going to waste much ;)
Small clusters are handy for things like Exchange badmail folder etc.
« Reply #12 on: 08 October 2008, 21:02:22 »
Windows XP Pro
TIA.  :y
HTH  :y
Absolutely no reason to partition for recovery purposes.
