Author Topic: Cam Cover Change  (Read 1167 times)
JesterRT
  • Stafford
Cam Cover Change
« on: 12 October 2008, 17:52:54 »
Well, fingers crossed.  Been under the bonnet for what seems like all afternoon.  Turns out that whoever fitted the cam cover gaskets last time had been to B&Q for sealant, and then applied it librally to everything that they put back together, including the plenum bolt that they've stripped the thread from.  There was red gunk (silicon sealant consistancy) on the underside of the breather box on top, around all the edges of the cam covers, on the EGR Valve, on the throttle body, and smeared on just about every pipe that I came across.
Anyway, gaskets done.  Fingers crossed that when I turn the key tomorrow morning that everything fires up.  Changed all the HT Leads as well, and not sure I've quite got the firing order right.
If you hear 'B0LL0X' at around 7.00am (no matter where you are in the country - I'll be yelling loud enough) then you can guess what's happened...
Hope your cam covers went more smoothly Lizzie!  (I think there may have been a few done this weekend)
Re: Cam Cover Change
« Reply #1 on: 12 October 2008, 19:43:52 »
Well after much cursing during the strip down it all went reasonably well Jester, but I just ran out of daylight to completely finish reassembly and full checking. ;)
Sounds as though yours went well! :y :y  Perhaps we should have done them together as I felt many times today I needed male company when things were so frustrating! :'(
Did you find oil in the plug holes as I did? :-?  It certainly justified the job for me. :y :y
JesterRT
  • Stafford
« Reply #2 on: 12 October 2008, 21:30:25 »
Haha... after my 'mishap' with the leads it's probably just as well we're nowhere near each other!
« Reply #3 on: 12 October 2008, 21:41:59 »
...... as I felt many times today I needed male company  ......
You'd have not got anything done!!!!!  ::)  ::)  ::) :y :y
