Author Topic: Cheap cambelt kit - recommendations?  (Read 1317 times)
Bandit127
« on: 14 October 2008, 18:37:05 »
The next job on mine is service & cambelt.
Service is easy - it will be all Vx bits on TC. No point going elsewhere based on price and it's good stuff to boot.
But what about the cambelt kit? IIRC the Vx kit is about £125 with TC? If so - is there a cheaper way to still get good kit? The Gates kit on ebay has been mentioned - about £80.
TIA.
Andyb
  • Lincoln
Re: Cheap cambelt kit - recommendations?
« Reply #1 on: 14 October 2008, 19:24:11 »
hi m8 you have answered your own question
if cash is tight go for gates  if not has to be vauxhall
« Reply #2 on: 14 October 2008, 19:25:54 »
Gates off ebay or a contitech kit from www.buypartsby.co.uk
Consider also a water pump at the same time (buypartsby also do contitech water pumps which seem very good)
gwa
  • Peterborough
  • Ginger With Attitude
« Reply #3 on: 14 October 2008, 19:55:10 »
If you buy a genuine Vx belt make sure (before you leave) that it has the timing marks on the belt, if not forget it and go for the Gates. We had one (Vx) the other week and it was a real pain so we went with gates and no problems. Good luck and post the end result so others will know.  :y :y
If it ain't fun, it ain't worth doin
Bandit127
« Reply #4 on: 14 October 2008, 20:01:36 »
About £100 all up for contitech (including water pump) from buypartsby. £71 without.
Having spent time doing lots of water pumps on Minis, I appreciate your advice.
Thanks.   :y
« Reply #5 on: 14 October 2008, 20:02:11 »
SKF kits are also good, containing Gates belts, so if you come across one at a good price go for it...
Robin Hood
  • Nottingham
« Reply #6 on: 15 October 2008, 07:21:31 »
Take a look at this Ebay shop for the Gates kits for the Omega...
http://shop.ebay.co.uk/merchant/autostuff18_W0QQ_nkwZQQ_armrsZ1QQ_fromZQQ_mdoZ
and just bid the minimum as he's been giving out "second chance offers" on less.    :y
Jay w
  • Plymouth/Poole
  • omega gone
« Reply #7 on: 15 October 2008, 08:14:04 »
on the subject of cambelt kits, can someone confirm that there is only one kit for the 2.6?
Seem to remember that i had a choice with mine, but the engine number no longer exsists as it has been replaced with a R******* number
willyboy
  • Leeds. West Yorks
  • Can Do !!
« Reply #8 on: 15 October 2008, 22:08:39 »
Robin hood is right these seem to be a good deal you end up paying £52 + off him for one had 2 recently off him he's ok  :y
Just make sure you order the right one he always sells 2 diffo vers for early & later V6 engines
« Reply #9 on: 15 October 2008, 22:58:52 »
Can recommend contitech kits.
