Pages: [1] 2 3  All   Go Down
Author Topic: been thinking of getting a compressor...  (Read 3854 times)
« on: 16 October 2008, 13:21:09 »
... to make things easier doing shocks, getting wheels off and so on, i was thinking of getting a compressor.
Saw this...
http://www.machinemart.co.uk/shop/product/details/hunter-25/path/diy-semi-professional-air-compressors-2
Any good?
What kind of money would i be looking at for something half decent?
Re: been thinking of getting a compressor...
« Reply #1 on: 16 October 2008, 13:23:26 »
I use 50 liter model as the mechanics recommended..
« Reply #2 on: 16 October 2008, 13:29:36 »
this one?
http://www.machinemart.co.uk/shop/product/details/hunter-55-air-compressor/path/diy-semi-professional-air-compressors-2
At £187 its a bit more than i would want to pay, but i guess thats about as cheap as i can go for something half decent?
« Reply #3 on: 16 October 2008, 14:05:05 »
this one?
yep..as an experience when you start to use even 50 liter pressurized air, it finishes quickly and engine starts again..But I think unless you will use it for painting its adequate
ps: they are very noisy in home ;D
« Last Edit: 16 October 2008, 14:06:00 by cem_devecioglu »
mantahatch
« Reply #4 on: 16 October 2008, 14:17:49 »
This is a newer version of what I have http://www.hydrovane.co.uk/products.asp?model=HV01RM%20(Receiver%20Mounted)&air=0%2E12&motor=1%2E1&Pressure=10&Speed=1450&section=detail&id=1475&Pressureunits=Bar%20g&MinPressure=&Flowunits=m3/min
They are quick and quiet compared to the piston type, they are more expensive I am afraid.
They are so quiet that I leave mine on most of the time and even on start up it cannot be heard outside of the garage.
HTH
Mike
Big Bri
  • Swansea
  • WELSH AND PROUD!
« Reply #5 on: 16 October 2008, 14:21:58 »
i bought 1 from aldi's for £69.99 had it for few months been handy also bought for £14.99 air impact wrench and kit and its got 3year warranty there good for the price
2.5HP, 1.87kW 230V motor
Operates from a 13amp plug
Air displacement: 270 litres/minute
Maximum working pressure: 8 bar (120psi)
24 litre capacity air receiver
Fully automatic STOP/START control
2 air outlets
2 pressure gauges
Fitted safety and non-return valve and drain valve
Accessory kit includes: gravity feed spray gun, professional spray gun, long nozzle sprayer/paraffin gun, blow gun, long nozzle extension for blow gun, jet blast wash gun, tyre inflator, 7 piece inflator/deflator set for footballs, li-los, inflatable boats, etc
Airbrush kit includes: airbrush, 60cc and 22cc paint jars, 1.5 metre air hose with air compressor fitting
10 metre and 5 metre air hoses
Quick release couplings
Omega Elite 3.0 V6 24V Manual
[img name=signat_img_resize]http://i262.photobucket.com/albums/ii103/bloosemore/dadsig-1.jpg[/IMG]
Martin_1962
« Reply #6 on: 16 October 2008, 14:44:35 »
I want to fit a vapour trap to my Aldi compressor but cannot find any compatible fittings
« Reply #7 on: 16 October 2008, 14:54:05 »
was this the one that was on offer at Aldi? Is it still there?
Big Bri
  • Swansea
  • WELSH AND PROUD!
« Reply #8 on: 16 October 2008, 15:08:42 »
yes it was the 1 on offer not sure if they still have them tho
Ken T
  • Stockport
« Reply #9 on: 16 October 2008, 16:16:01 »
HTH
Mike
Yes, Hydrovane are very good and quiet. The air comes out in a smooth flow, you don't need a receiver to smooth out the pulses that a piston type gives. I have a 3 ph one, which I run off a small inverter and it works very well. Here's one on FLeabay  http://cgi.ebay.co.uk/USED-HYDROVANE-15-COMPRESSOR-GOOD-WORKING-CONDITION_W0QQitemZ190258411117QQihZ009QQcategoryZ22662QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
which works of 240V. If yo don't mind getting an inverter here's a 3ph one
 http://cgi.ebay.co.uk/hydrovane-5-compresser_W0QQitemZ150303157499QQihZ005QQcategoryZ30906QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Because they are used a lot in industry, you can still get spares easily, several people sell series 5 service kits, oil etc.
Ken
« Reply #10 on: 16 October 2008, 16:22:22 »
Hydrovanes are good but should be maintained more, there also VERY expensive new!
When considering which one, consider the application you are targeting as this has a big effect on what you REALLY need.
mantahatch
« Reply #11 on: 16 October 2008, 17:47:18 »
HTH
Mike
Ken
Wow what a price, that is my exact compressor except mine is in mint condition compared to that one highlighted above.
Yes they do require more frequent oil changes, and you really need a oil filter thinghy for paint spraying. But they are brilliant for lubrication normal air tools.
Mike
P.S. Thank god mine was free. (not stolen I might add)
« Last Edit: 16 October 2008, 17:47:47 by mantahatch »
theolodian
  • I need a new avatar.
« Reply #12 on: 16 October 2008, 18:21:04 »
Wouldn't it be easier to just get one of those cordless electric impact guns?  :-?
« Reply #13 on: 16 October 2008, 20:09:43 »
General car work, time saving tool, as members know i aint that strong  ::)
Main things i can for see..
Pumping up tyres - Getting hacked off with petrol station ones not working.
Removing wheel nuts - make things easier
Rear shock bolts / diff bolts for springs and shock replacement.
« Reply #14 on: 16 October 2008, 20:29:51 »
For bolts that you can't undo by hand, not sure airguns are the solution - frequently shear them ;)
I do happen to have a VAT Free invite for Machine Mart (this Sun I think) ;)
Pages: [1] 2 3  All   Go Up
