Author Topic: Mrs TMX's Rover  (Read 1167 times)
tmx
  • Herefordshire
    • 3.2 MV6 2002
Mrs TMX's Rover
« on: 19 October 2008, 12:06:24 »
Does anyone know if you can disable a Rover Imobiliser as Mrs Tmx's Rover has decided that it wont disarm the imobiliser anymore its a 1998 (R) Rover 414 Si preferbly i would like to get shift of the Rover but cant sell it as it plays an annoying tune and refuses to start!
TIA
JonArgraig
  • Isle of Angelsey
  • The Camera Ninja
Re: Mrs TMX's Rover
« Reply #1 on: 19 October 2008, 12:15:43 »
Do you have the rover version of the carpass?
There is a overide but you need the code
tmx
  • Herefordshire
    • 3.2 MV6 2002
Re: Mrs TMX's Rover
« Reply #2 on: 19 October 2008, 12:54:17 »
got the code but it refuses to awknowledge the code! tried the process with turning the key in the door as described in the haynes manual
Bandit127
Re: Mrs TMX's Rover
« Reply #3 on: 19 October 2008, 13:11:56 »
Don't know if it adds anything to Haynes, but:
After every time you turn the key, return to the "normal" position.
1. First, key in the lock
2. Turn the key 4 times to the lock postition to reset the system.
then, turn the key to unlock as many times as your first digit of the EKA code is, so if the first digit was "5", you'd turn the key 5 times to the unlock position
3. Next, turn the key back to the lock position as many times as the second digit
4. again, back to unlock as many times as the 3rd digit
5. back to lock as many times as the 4th digit
6. that's the code input. now turn it once to unlock, and you should be done!
So, in short (with n meaning number of the digit, L being lock and U being unlock)
LLLL, Un, Ln, Un, Ln, U
for example, if your code was 4567 you would do
LLLL UUUU LLLLL UUUUUU LLLLLLL U
From http://forums.mg-rover.org/showthread.php?t=82377&highlight=Key+Access+Code
tmx
  • Herefordshire
    • 3.2 MV6 2002
Re: Mrs TMX's Rover
« Reply #4 on: 19 October 2008, 13:23:41 »
thanks bandit rover now be working!!!!!!!!!!!!!!!!!!!!!!!!!! your a *  :y :y
haynes manual doesnt say for 2nd digit go the other way! thanks rover can now be sold !
