Author Topic: Cam covers xlkfdjkldglkjsdgalkj;!!!!!!!!!!  (Read 2242 times)
Martin_1962
« on: 18 October 2008, 18:49:48 »
What a pig of a job, very sore as well.
DOne the drivers side - now I have to do the passenger side, which looks horrible to do.
ANyway watching TV and I'll be back later and going to take some Ibuprofen
psychnurse
  • Leominster, Herefordshire
  • Whats in the fridge today? Beer and Sausages....UM
Re: Cam covers xlkfdjkldglkjsdgalkj;!!!!!!!!!!
« Reply #1 on: 18 October 2008, 18:52:44 »
 ;D ;D ;D
Best of luck matey  ;) ;)
I am sure you will crack it  :y
« Reply #2 on: 18 October 2008, 19:01:31 »
All the very best Martin, as I am afraid to say you have get the worst side left to do! :'(
My advice is you tie all cables and pipes that you cannot remove up out of the way.  That is the only way that I believe you can get the cover back on without disturbing the gaskets you have so carefully placed into position! :o ;)
Martin_1962
« Reply #3 on: 18 October 2008, 20:01:34 »
OK watched Merlin - a bit of fun, anyway not too bad now, the back has survived, but dreading the passenger bank, last time I went there I broke the cable tray!
Also dreading my back conking out halfway through!
Markjay
  • London
« Reply #4 on: 18 October 2008, 20:03:10 »
Good luck with it.  :y
Done the drivers side, luckily the passenger side wasn't leaking...  8-)
Alas, no more Omegas....
« Reply #5 on: 18 October 2008, 20:04:22 »
.........whilst sitting on the engine.....not good, not a good thought at all Martin! :o :o :D ;)
Have fun! :D :y
Martin_1962
« Reply #6 on: 18 October 2008, 20:08:43 »
I messed up a fleece supporting myself to avoid straining the back, bonnet is still up a bit as plenum is too wired to car and inlet manifold has too many cables to undo.
Just hope the cabling goes back easily when I refit as the last time I had the plenum off was to fit the cables causing the issue now (cut injectors)
Managed to use a piece of wood to fill in the gap between bonnet and alarm switch so if it gets lifted I will know.
Martin_1962
« Reply #7 on: 18 October 2008, 20:10:51 »
Mainly sat on the slam panel!
Martin_1962
« Reply #8 on: 19 October 2008, 12:32:27 »
Finished the passenger side around 10:30, just got the plenum refitted and no misfires so everything reconnected.
Just got to do the scuttle panel and wipers.
The sealant on the passenger bank will have until 14:00 to harden enough as I need to use the car!
Martin_1962
« Reply #9 on: 19 October 2008, 12:33:12 »
Taken a long time as every half hour take a 10 minute break for back resting
stowboy
  • stow on the wold
« Reply #10 on: 19 October 2008, 12:42:31 »
just keep ploddin on :y
« Reply #11 on: 19 October 2008, 12:49:45 »
Well done mate :y
« Reply #12 on: 19 October 2008, 13:27:45 »
That is great news Martin, as it is always a great relief to see it finally all working again without complications! :y :y :y :y
Martin_1962
« Reply #13 on: 19 October 2008, 17:52:21 »
My back is absolute agony now!
« Reply #14 on: 19 October 2008, 17:55:08 »
Go and have a lovely hot, steamy bubble bath and allow it all to soak away Martin in celebration of finishing yet another miggy job! :D :D ;)
