Author Topic: My 2.2 is in the FS section!  (Read 1989 times)
Re: My 2.2 is in the FS section!
« Reply #15 on: 20 October 2008, 09:42:25 »
i just don't have the space anymore for projects, we have 4 cars already  ::)
« Reply #16 on: 20 October 2008, 12:25:59 »
If it's going for project money, then I will be interested :y
Not quite that cheap James  ;)
Project money isn't always mega low... my Elite turned out a "project" and that cost me £1300.....
I guess a potential buyer (I am mildly considering it as a business car!) needs to consider the cost of repairing.
1) Those snapped exhaust manifold studs - still not sure I could drill in situ and make a good job, so for a DIYer it's probs going to be a head off job, so pretty much a top end rebuild for a proper fix - during which is a good time to find that noisy lifter!
2) New Rad, and flushout out of the bodgeweld..
3) New ABS ECU and relevent setting up with Tech2
4) Exhaust's bandaged - so probably will want new sections soon.
So - market value, minus the cost of those jobs, I'd say is probably fair?  :)
Taxi_Driver
« Reply #17 on: 20 October 2008, 19:00:10 »
Current plan if i get it fixed myself.....local garage is going to drill in situ, using a right angled air drill.....only a pilot hole, then tap a left handed thread.....with conversations i had with others with snapped studs on 4pots....the studs will probably come out when trying to tap them...if not a left threaded bolt and unscrew em  :y
But upto you, how you tackle the job if you become the owner of it  ;)
Id agree with the new rad, but a secondhand abs ecu or get the one fitted repaired......would be fine, in fact I will prolly get it repaired as it wouldnt need tech2 work then  :y
Exhaust I agree with.......tho if i end putting it on autotrader I wouldnt touch the rad or exhaust  ::)
PM me James, if you wanna make an offer  :y
