Author Topic: has anybody done this?  (Read 1397 times)
jim351
  • Bognor Regis, West Sussex
« on: 28 October 2008, 12:37:56 »
Hi, im quite new to this site but i was just wondering if anyone that has had the oil cooler problem on the V6 has instead of replacing it they have just blocked it off and used an external on?
JonArgraig
  • Isle of Angelsey
  • The Camera Ninja
Re: has anybody done this?
« Reply #1 on: 28 October 2008, 12:45:06 »
I wouldn't risk it, your compromising both the water and oil system's - besides the cost isn't too bad to be fair ( I can't speak... bought a new car when mine went  :D )
jim351
« Reply #2 on: 28 October 2008, 12:51:14 »
oh right, what sort of cost is it to do? so its worth looking at cars that are for sale saying the head gasket is gone? it could be the cooler then? what are the signs its the cooler?
JonArgraig
  • Isle of Angelsey
  • The Camera Ninja
« Reply #3 on: 28 October 2008, 12:54:25 »
£70 to £100 for the cooler,
I was quoted from a "friendly" vauxhall specialst £50 and a pack of stella to fit
signs are mayo in the header tank, Oil in sump fine, some over heating
pain in the arse to clean out though...
« Reply #4 on: 28 October 2008, 13:05:16 »
The internal oil cooler is a neat solution because it can't overcool the oil. It won't ever get colder than the coolant but the cooler can dump heat from the oil into the coolant when the engine is working hard. With an external cooler, you would need an oil thermostat and bypass arrangement to prevent overcooling, you will have longer oil lines increasing the risk of damage and pressure drop.
If the coolant is kept in good condition the oil cooler shouldn't fail, but because it sits at the junction of parts made from cast iron, aluminium alloy and stainless steel, it's just asking for corrosion when the antifreeze gets old.
jim351
« Reply #5 on: 28 October 2008, 13:13:02 »
oh i see, on my Mustang i use the cooler in the rad aswell, wonder why VX didnt put it in the rad? after all they have been there for years on alsorts of cars...
JonArgraig
  • Isle of Angelsey
  • The Camera Ninja
« Reply #6 on: 28 October 2008, 13:14:38 »
Saving space on FWD appilcations and the afore mentioned heat issues I guess
JonArgraig
  • Isle of Angelsey
  • The Camera Ninja
« Reply #7 on: 28 October 2008, 13:16:42 »
http://cgi.ebay.co.uk/Vauxhall-Vectra-Omega-Signum-Cavalier-V6-Oil-Cooler-NEW_W0QQitemZ230302772261QQcmdZViewItem?hash=item230302772261&_trkparms=72%3A1301%7C39%3A1%7C66%3A4%7C65%3A12%7C240%3A1318&_trksid=p3286.c0.m14
Oil coolers can be found on ebay - not sure on stealer ship prices
