Author Topic: Petrol additives.  (Read 950 times)
manny
  • bromorough.Wirral.
Petrol additives.
« on: 29 October 2008, 21:10:40 »
Have read about oil additives on the forum and how there not rated.What about petrol additives?There are many out there and i admitt to buying it now and again(slick 50 £15.00.)But do they work?
2001 OMEGA MV6
Re: Petrol additives.
« Reply #1 on: 29 October 2008, 21:15:41 »
I occasionally give mine some Forte for the injectors
iainb
  • West Midlands
« Reply #2 on: 29 October 2008, 21:27:31 »
I put some injector conditioner in once a month and find it helps with the cold start the other alternative is shell optimax which has the same effect
ngrainqey
  • rotherham
    • BMW E92, 2.6 CD F/L Est.
« Reply #3 on: 29 October 2008, 21:29:24 »
personally i'v never needed petrol/oil addatives but would consider them for the fuel as i'd rather not get clogged injectors, dont the fuel addatives also help reduce the coke that gathers round the valves?
V8!!!!
Bandit127
« Reply #4 on: 29 October 2008, 21:47:57 »
I can only speak fo my experience on motorbikes. That is Silkolene FST contains a solvent that mixes with water. It does 2 things very well...
1. Mops up water that collects in the fuel system (tank, float chamber etc).
2. Stops carb icing (not an issue for most cars).
It's the only thing that got me through the winters on my 600 Bandit.  :y
FYI:
http://www.silkoleneoil.com/techtip7.htm
Martin_1962
« Reply #5 on: 29 October 2008, 21:56:15 »
I use Redex occasionally or just use BP or Shell petrol
LPG cars are more liable to clogging
