Author Topic: Unpleasant pong...  (Read 1320 times)
jereboam
  • Suffolk
    • 1999 Omega Elite 3.0
Unpleasant pong...
« on: 30 October 2008, 20:28:32 »
It’s been an expensive few weeks.
·      First off, the airco failed.  Took it in to garage, only needed re-gassing – working fine now.
·      Then the battery died on the first cold day this month – been expecting that, though.
·      Then the driver’s door lock failed – works with key (but sets off alarm), won’t work with remote.  Passenger door has been unreliable for some time so booked it in to be fixed.
·      Then the insurance expired and the ratbags upped my premium by 30% for no reason whatsoever and consequently lost my business.
·      So that made me think about the MOT – reckoned it must be due, but couldn’t find car documents.  They eventually surfaced, and it turned out that the MOT was actually overdue – oops!
·      So, asked garage to do MOT and service.  No problems – no advisories.  But they didn’t manage to fix the door locks – they say I need 2 new solenoids but they don’t know where to source them from – presumably VX too expensive.
So, anyway, last weekend, the wife and I set off to visit the youngest son in Bristol and the in-laws in Wales.  Lousy journey down – overturned lorry on the M4.  Had a reasonable weekend, set off home again.  Just before Reading services, there was a clattering noise which sounded like it came from inside the car – I thought the wife had dropped something which had hit the centre console or door pocket, but she hadn’t.  I stopped at the services and checked all round to see if anything had fallen off – it had just been serviced, so I was thinking about the wheel bolts.  All looked OK and the car was running fine.  We took it easy and got back to Suffolk without incident.
But now there’s a burnt oil smell every time I use the car, and the electrics seem to be even more erratic than usual.   I suppose it’s got to go back to the garage, but I really can’t work up much enthusiasm.
Beginning to think bye-bye Omega…
Tony H
  • liverpool
  • Black Elites are luurvley
Re: Unpleasant pong...
« Reply #1 on: 30 October 2008, 20:35:11 »
Shop around year on year for the last three years I've managed to get my premium reduced by changing insurers.  :y
« Reply #2 on: 30 October 2008, 20:37:06 »
Know how you feel, been feeling the same over the past 2 months but my old girl is holding up at the mo, your burnt oil smell sounds like the rocker cover gaskets.
fatboyfat
  • leeds
« Reply #3 on: 30 October 2008, 20:42:17 »
My car has "unpleasant pong" which i am also thinking is cam cover seals,have you seen smoke in engine bay mine has smoke when engine gets hot,also no smell until engine warms up. :y
God only created a few perfect men
The rest he gave them hair
« Reply #4 on: 30 October 2008, 20:50:21 »
99.9% thats your cam covers m8, mine are doing it again at the mo will do it myself this time >:( But yeah check the spark plug holes see if there is oil in them, if there is then its your rocker covers.
jereboam
  • Suffolk
« Reply #5 on: 31 October 2008, 09:07:26 »
Yeah - I think that's what the problem is too.  They were replaced last year, though.  I have no idea whether he used original parts or cheapo ones - at least I've learned about that from this forum.  As I've mentioned before, my garage owner absolutely hates the Vauxhall V6 engine, for some reason, but he usually does a good job.  However, it took him 3 attempts to identify the oil leak last time, although to be fair, there was a water leak at the back of the engine as well at around the same time.
Anyone got any idea about the noise I heard?  Surely it can't have anything to do with the rocker cover gaskets?
I'll take it to the garage and report back later.
Tony H
  • liverpool
« Reply #6 on: 31 October 2008, 17:07:43 »
If he did not clean the breather system at the same time he's wasted his time and your money.
« Reply #7 on: 31 October 2008, 17:11:33 »
As Tony says, there's no point in replacing the cam cover gaskets without cleaning out the breathers and you should use only genuine gaskets
doog
  • Alloa Central Scotland
« Reply #8 on: 31 October 2008, 17:14:47 »
my car has an unpleasant pong too
it goes away when the wife gets out  :D :D
Doug
me at kick boxing
