Author Topic: astra keeps cutting out  (Read 1924 times)
kris9128
« on: 01 November 2008, 15:57:00 »
the wifes astra keeps stalling. only does it when it gets upto running temp. anybody know what could be causing the problem. tired of her whingeing at me now.
Tefal
  • herts
Re: astra keeps cutting out
« Reply #1 on: 01 November 2008, 15:59:14 »
what engine?, year?
kris9128
« Reply #2 on: 01 November 2008, 16:01:04 »
oh yeah, sorry. 1800 on a V plate. have checked throttle body and it's rather dirty.
unlucky alf
  • worksop, notts
« Reply #3 on: 02 November 2008, 00:04:52 »
i dont know if this will help you but had the exact same problem on a cav sri, slightly older i know but on the injection side between the manifold i had a diaphram/vacuum unit [metal pot thing!] i changed that & it cured it, you might be lucky if the setup is the same ;)
BigAl
  • Bromley, Kent
    • '07 Forester
« Reply #4 on: 02 November 2008, 00:32:00 »
1800 on a V plate
at a guess - the engine is to small ;D
kris9128
« Reply #5 on: 02 November 2008, 09:51:18 »
cheers mate will nip out and have a look, are they expensive to replace
kris9128
« Reply #6 on: 02 November 2008, 09:52:04 »
1800 on a V plate
it's plenty big enough for a woman
Martin_1962
« Reply #7 on: 02 November 2008, 10:06:47 »
Missing some cylinders?
v6venom
  • nr wareham dorset
  • banned due to bad trader references
« Reply #8 on: 02 November 2008, 10:15:44 »
idle control valve at a guess mate ??
small barrel shape item located on side of the throttlebody ..
if the t/b is really mucky idle will be aswell ...
2 x small allen key bolts n pop it of (take care of gasket) fill with wynns carb cleaner and leave for 1/2 hr then empty & flush with wd40 and refit ...
use the wynns and a lint free cloth to do the body aswell opening the flap manually to get right in ....
should sort ya probs   :y
« Last Edit: 02 November 2008, 10:16:27 by v6venom »
kris9128
« Reply #9 on: 02 November 2008, 10:18:29 »
looks like i know what i'm doing this afternoon then. cheers mate.  ;D ;D ;D
« Reply #10 on: 02 November 2008, 10:19:15 »
1800 on a V plate
??????????!!!!!!!!!!!!!!**xxY%$ What!!!!!!! :o :o :o :o :o :o :o :o :o  I hope your wife reads your comment and drags you by your short and curlies out of your cave! ;D ;D ;D ;D ;D ;D ;D ;D ;D ;)
kris9128
« Reply #11 on: 02 November 2008, 10:30:33 »
1800 on a V plate
i wasnt meaning a woman of your experiance and capabilities lizzy.  :-[ :-[ :-[ :-[
« Reply #12 on: 02 November 2008, 10:32:20 »
1800 on a V plate
Oh ok Kris, then I forgive you completely!! ;D ;D ;D ;D ;D ;D ;D ;D :y
kris9128
« Reply #13 on: 02 November 2008, 10:36:13 »
i reckon you could have a 2 ltr ;D ;D ;D ;D
« Reply #14 on: 02 November 2008, 10:40:10 »
Typical bloke, you have to spoil it!! ::) ::) ::) ;D ;D ;D ;)
Anyway, back to your thread Kris, when was the Astra last given a major service? :-?
