Author Topic: darn SQL  (Read 1157 times)
darn SQL
« on: 06 November 2008, 11:04:55 »
Does anyone know how to format a colum with SQL to remove a decimal point and reformat it to a numerical column rather than character?
« Last Edit: 06 November 2008, 11:10:33 by tunnie »
Re: darn SQL
« Reply #1 on: 06 November 2008, 11:07:30 »
Does anyone else understand the question?  :-/  ;)  ;)  ;)
Phil B
  • South Wales
Re: darn SQL
« Reply #2 on: 06 November 2008, 11:17:44 »
Yep. Just looking through me scripts
Phil B
  • South Wales
Re: darn SQL
« Reply #3 on: 06 November 2008, 11:19:31 »
What data type is the column now?
« Last Edit: 06 November 2008, 11:19:44 by phil65412 »
Phil B
  • South Wales
Re: darn SQL
« Reply #4 on: 06 November 2008, 11:30:21 »
If it's already a text column, use
update dbo.table
set column2 = replace(column2,'.','')
replaces the . with nothing, then change the datatype in manager to a numeric one? Just tried it on a test table seemed to work ok
Re: darn SQL
« Reply #5 on: 06 November 2008, 11:45:17 »
if for display,print purpose
select convert(decimal(25,0),field) from table
or
select cast(field as decimal) from table
this will cut the fraction part and still keep the numeric representation
or if you want to modify the column you must use
alter table TABLE alter column COLUMN  decimal(25,0) NOT NULL etc
« Last Edit: 06 November 2008, 12:04:44 by cem_devecioglu »
Page created in 0.009 seconds with 20 queries.
