Author Topic: This should pass a few hours  (Read 2839 times)
Re: This should pass a few hours
« Reply #15 on: 07 November 2008, 22:14:11 »
Quite good fun when you get the idea....... ;D ;D ;D
« Reply #16 on: 07 November 2008, 22:30:17 »
thank you   on to 4 balls now
and I'm struggling with that one now.  :-[ :y
dieseldean
  • chesterfield
« Reply #17 on: 07 November 2008, 22:41:35 »
type of game played on commodore64 as kid ;D ;D ;D
PaulW
  • Somewhere near Manchester
  • Come on you fiend!
    • Some crappy Insignia
« Reply #18 on: 07 November 2008, 22:53:50 »
http://FantasticContraption.com/?designId=4015789
Humbugs...
« Reply #19 on: 07 November 2008, 23:08:48 »
That's brilliant!!  :y Did you work that out yourself? ;)
« Reply #20 on: 07 November 2008, 23:11:04 »
Very impressed......... :y
PaulW
« Reply #21 on: 07 November 2008, 23:11:34 »
Its similiar to some video i saw somewhere with some twigs and rotating bits  ::)  but that one is the one I did :)
Humbugs...
« Reply #22 on: 07 November 2008, 23:15:54 »
I took a look at the next one, too many whisky's to even think about it.... ::) ::) ::)
PaulW
« Reply #23 on: 07 November 2008, 23:21:10 »
choo choo :)
http://FantasticContraption.com/?designId=4011675
Humbugs...
Gaffers
  • NE Hampshire/Surrey
    • Ford Ranger Wildtrak
« Reply #24 on: 08 November 2008, 06:23:08 »
Im stuck on down under, I liked your way of doing 4 balls, mine worked but was completely over engineered compared to yours!  ;D
Welung666
« Reply #25 on: 08 November 2008, 08:09:50 »
Same here, I've always thought about problems like that and tend to over complicate them. But on down under I used 2 orange balls on the bottom, 2 pink on the top, making a tight square. Join the 4 outer balls together to make the square and cross all to centre so it looks like a X in a box. It drives off hte edge, lands upside down and drives the other way to the goal :y
« Last Edit: 08 November 2008, 08:11:54 by Welung666 »
« Reply #26 on: 08 November 2008, 09:50:51 »
If you want to work them out for yourself then don't look at this ::)
http://www.freegamesnews.com/en/?p=4545
