Author Topic: Astra 1999 1.6 16V cam belt failure  (Read 903 times)
mantahatch
« on: 08 November 2008, 11:07:56 »
Does anyone no how terminal this will be please, father in laws tensioner has failed at approx 50mph.
I am expecting major valve damage, but is it likely to do anything to vavle guides, head or pistons.
Thanks in advance.
You no what I will be doing for the next week.
Mike
P.S. he is an elderly retired mechanic  and I have told him on more than one occasion to get it changed, but he would not listen, even on trade club a head is £700+.  :(
Jay w
  • Plymouth/Poole
  • omega gone
Re: Astra 1999 1.6 16V cam belt failure
« Reply #1 on: 08 November 2008, 11:11:28 »
having done a 1.4 16v that lunched the cam belt at low speed i would say start looking for a s/hand head, it will be cheaper.......
the one that i did lunched all 16 valves and half a dozen guides
because the valves hit the piston at angle they have been known to damage rings due to the valve/piston impact forcing the piston ito the bore, but that is unusual
not a hard job to do though
« Last Edit: 08 November 2008, 11:13:15 by jay_w »
Jay w
  • Plymouth/Poole
  • omega gone
« Reply #3 on: 08 November 2008, 11:21:26 »
I have used these guys before and was pleased with the quality
http://cgi.ebay.co.uk/Vauxhall-zafira-Cylinder-Head-1-6-1-8-2-0cc16v-Ecotec_W0QQitemZ180245801642QQcmdZViewItem?hash=item180245801642&_trksid=p3286.c0.m14&_trkparms=72%3A1301%7C66%3A4%7C65%3A12%7C39%3A1%7C240%3A1318
WOW!! that is good value.....
add another £150 for headset, bolts and cambelt kit and you are on the road again
mantahatch
« Reply #4 on: 08 November 2008, 11:24:44 »
Thanks chaps, yes that is good value and says it includes gaskets and bolts.
But did wonder if I should buy genuine bolts and gaskets.
Mike
Jay w
  • Plymouth/Poole
  • omega gone
« Reply #5 on: 08 November 2008, 11:34:13 »
Mike
missed that bit, even better bargain then.....
The corsa i did had aftermarket gaskets and bolts used....they have been ok
« Reply #6 on: 08 November 2008, 11:42:13 »
The head gasket and bolts will be fine.
I would re-use the old cam seals (pattern are crap) and get genuine cam cover gaskets plus exhaust manifold gasket.
