Author Topic: been busy today  (Read 3030 times)
shanjon
Re: been busy today
« Reply #15 on: 07 November 2008, 18:46:23 »
how did you attach them bud ??  :-/
basically i was fortunate enough to get all the clips with mine although i ditched nearly all of them except for the one at either end of each moulding that has the screw in them and put some 3m double sided foam tape in the middle section to hold that secure,
when drilling the holes for the screws i found the best way was to put the two end clips on the moulding and put a dab of hammerite on the back of the small round flat part of the clip where the screw goes into the centre,
i then offered it up to the door and gently pressed against the door and it left two perfect circles in which you drill the hole directly in the centre and it should line up perfectly
i know this might not be the best way but i found it worked perfectly well for me :y
markey mark
  • SLady bitshorpe north lincs
Re: been busy today
« Reply #16 on: 07 November 2008, 18:52:17 »
sweet cheers matey  :y
shanjon
Re: been busy today
« Reply #17 on: 07 November 2008, 18:54:29 »
glad i could be of help :y
unlucky alf
  • worksop, notts
Re: been busy today
« Reply #18 on: 09 November 2008, 23:04:31 »
looks well good, how about the front bumper?, does a facelift one fit with a bit of poking & prodding? ;)
Albatross
  • Bedford
  • An LSD & an S2000!
Re: been busy today
« Reply #19 on: 09 November 2008, 23:59:46 »
It looks really good. From the photos it appears that you have done an amazingly good job of the spray work, well done.
shanjon
Re: been busy today
« Reply #20 on: 10 November 2008, 22:24:04 »
Thats next on my list, i already have the facelift headlights i just need the bonnet and bumper
shanjon
Re: been busy today
« Reply #21 on: 10 November 2008, 22:34:04 »
Thank you very much :), i sprayed the basecoat on friday morning and around lunchtime i sprayed the lacquer then i forced myself to lock the garage and go out to visit the in laws to keep me away from it lol,
you see once it is sprayed im rather impatient and i would have tried fitting it back to the car too early and would of ended up with fingerprints all over  ;D
unlucky alf
  • worksop, notts
Re: been busy today
« Reply #22 on: 11 November 2008, 10:35:36 »
how are you going to get the bonnet to fit?, im sure the slam panel is totally different ;) ive been offered a rear f/l bumper for mine but thought £70 is a bit steep :(
markey mark
Re: been busy today
« Reply #23 on: 11 November 2008, 10:43:59 »
no slam panel is same as are wings just need to change bonnet headlights and bumper and bar  :y
unlucky alf
  • worksop, notts
Re: been busy today
« Reply #24 on: 11 November 2008, 10:46:43 »
will the f/l bumper fit with a bit of prodding to my old tractor or are the headlights etc needed? :)
markey mark
Re: been busy today
« Reply #25 on: 11 November 2008, 10:51:46 »
front wont no you would need bonnet and headlights  but rears bolt on fella  :y
shanjon
Re: been busy today
« Reply #26 on: 11 November 2008, 11:31:35 »
and headlight trims :y
markey mark
Re: been busy today
« Reply #27 on: 11 November 2008, 11:37:00 »
ahh yes forgot about those  :D
