Author Topic: Today's double-Doh  (Read 11304 times)
Markjay
  • London
Today's double-Doh
« on: 05 August 2006, 13:38:13 »
I was going to change the oil pressure switch today – well first Doh for not checking the nut size – it’s 24mm and my socket set only goes up to 23… :(
Second Doh for not checking that the Bottle jack I bought from Machine Mart a couple of weeks ago can actually lift the car high enough for the axle stands I bought on the same occasion… Well I’ll need either a higher-lift jack or lower stands… :(
Alas, no more Omegas....
hotel21
  • The Kingdom of Fife
Re: Today's double-Doh
« Reply #1 on: 05 August 2006, 13:46:39 »
Or a shifting spanner and a block of wood to sit the jack on, to get the height needed....
Broocie
« Reply #2 on: 05 August 2006, 13:49:47 »
i was almost in the same boat, i bought some axel stands from machine mart... the are red with a white Y shape to stand the car on.
I used my old trolley jack and its only just powerfull enough to lift i high enough to fit the stand underneath....
Markjay
  • London
« Reply #3 on: 05 August 2006, 14:02:26 »
Broocie
Thanks Broocie, I fully un-screwed the top bolt while the jack was in the lowest position until it touched the car, but I think that total lift is just not enough... didn't even get the wheel off the ground. Serves me right for buying the cheapest one .... I used the car's own jack, and just about managed to squeeze the stand in (just the base bit though without the actual stud and bracket), but I don't like them screw-type jacks too much as they are not very stable.
MartinP
  • Dudley
    • BMW 320D
« Reply #4 on: 05 August 2006, 14:26:22 »
Check you spark plug sockets, amongst mine I had a 24mm  ;)
Markjay
  • London
« Reply #5 on: 05 August 2006, 14:29:40 »
On another note, members of 'the other site' may recall that Vx gave me an advisory on both front wheel bearings, and I found it odd that they should fail after only 45k miles - both of them...
Well I checked it myself today, there is the tiniest 'knock' from top-to-bottom (12 to 6 o’clock), but no knock at all from side to side (3 to 9 o'clock), suggesting it's a suspension component (from memory, the lower wishbone joint...?) and NOT the bearing.
Markjay
  • London
« Reply #6 on: 05 August 2006, 14:33:56 »
Thanks issunaz, good to see you on this side...:)
I just did, I only have the one spark plug socket, and it's called a '10mm' but is actually 14mm. Off to the local tool shop then...
MartinP
  • Dudley
    • BMW 320D
« Reply #7 on: 05 August 2006, 14:43:21 »
Halfrauds with TC  ;)
Markjay
  • London
« Reply #8 on: 05 August 2006, 18:47:36 »
Halfrauds with TC  ;)[/quote]
Yes Sir, I am now the proud owner of a deep 24mm spark plug socket curtsey of Halfords... I don't have a Halfords Trace Card though (don't think they would be impressed by my Vauxhall Trade Club card) so I paid the full amount of £6 (give or take a few pennies). Thank you kindly issunaz for the helpful advice...
hotel21
« Reply #9 on: 05 August 2006, 19:15:07 »
Markjay - I would still say use a large block of wood under the bottom of the bottle jack to get the extra height, alongwith the screw portion.  Also, have a good look to ensure you get the lowest portion of the suspension mounts (not just the chassis legs!!) to get maximum lift.  Don't use housebricks under the jack as they crack and crush and could drop the car on you before you have time to get the axle stands in.
Broocie
RonaldMcBurger
« Reply #10 on: 05 August 2006, 20:26:35 »
You can borrow my proper 2 ton high lift garage trolley jack anytime, with the 6 ton high lift axle stands if you want. [smiley=vrolijk_26.gif]
Sorry. Salt and wound springs to mind here
Markjay
  • London
« Reply #11 on: 05 August 2006, 20:37:11 »
Not at all. Much appreciated offer. When can you come round my house with them?  ;D
Markjay
  • London
« Reply #12 on: 05 August 2006, 20:37:56 »
Broocie
Thanks Broocie, will give it a go again tomorrow....
sounds2k
  • Queenborough, Kent
    • Saabs and a Jag XFR
« Reply #13 on: 05 August 2006, 21:06:55 »
this jack will do the job (I bought one on the recommendation of a mate) - but it ain't cheap, or light (about 30Kg!). However, it should last a long time ...
« Last Edit: 05 August 2006, 21:12:45 by sounds2k »
Markjay
  • London
« Reply #14 on: 05 August 2006, 21:17:41 »
Yep, saw this one in the shop... good stuff. I've got no garage, have to keep the stuff in the boot, so only the smallest bottle jack will do for me... :(
