Author Topic: Computer help Pretty Pleaseeeeeeee  (Read 4306 times)
Re: Computer help Pretty Pleaseeeeeeee
« Reply #15 on: 13 November 2008, 21:28:37 »
I am not on a wireless system, but when I have browser issues and no access my skype still works.
Sometimes just a modem reboot solves the problem, but I would have thought that and checking unplugging/plugging the telphone lines in has allready being tried?
Done that, I I pull out the yellow cable it say nework connection unplugged.... ::) ::) ::)
Welung666
« Reply #16 on: 13 November 2008, 21:29:02 »
Is MSN still logging in?
What does it say on Device Manager about Network Adapters?
« Reply #17 on: 13 November 2008, 21:30:20 »
so lan card working..
if registry for ie is broken the easiest way is to install firefox or an upgrade ie from cdr from usb from another disk anyway..
or re-install :-/
« Reply #18 on: 13 November 2008, 21:31:07 »
MSN Working, cant say I understand the rest, :-[ :-[ :-[
« Reply #19 on: 13 November 2008, 21:33:47 »
or re-install :-/
Tried puting firefox on but would not read the 'stick'
re-install :question   what, the BT disc??
« Reply #20 on: 13 November 2008, 21:33:51 »
bring here..tonight I can solve for you ;D :y
« Last Edit: 13 November 2008, 21:34:07 by cem_devecioglu »
« Reply #21 on: 13 November 2008, 21:35:12 »
or re-install :-/
if you can write CDRs from other pc or lappy use CD-rom to install them..
for re-install I mean re-install vista or xp
« Last Edit: 13 November 2008, 21:36:08 by cem_devecioglu »
« Reply #22 on: 13 November 2008, 21:36:32 »
swmbo says that she will bring it over.......... ;D ;D ;D :y
what is this   192. ***. 1. ***  :question ? left the numbers out in case they are secret :-/
« Reply #23 on: 13 November 2008, 21:38:36 »
or re-install :-/
Thinkthis might be going back to the shop for an expert to sort :-[ ::) ::) ::)
« Reply #24 on: 13 November 2008, 21:39:16 »
 ;D
ip numbers..
« Reply #25 on: 13 November 2008, 21:41:31 »
or re-install :-/
by the way will not read the stick because of a driver problem dont you have any cd-rom on it ?
Bandit127
« Reply #26 on: 13 November 2008, 21:41:59 »
Don't know if this will work in Vista. But worth a go.
Start
Run
Type cmd and press OK
Type ipconfig /release
then
ipconfig /renew
then
ipconfig
? What is the number in IP address (something like 192.168.0.2)
? What is the number in Default Gateway
« Last Edit: 13 November 2008, 21:43:01 by Bandit127 »
« Reply #27 on: 13 November 2008, 21:42:28 »
or re-install :-/
will be easier but costly :-/
« Reply #28 on: 13 November 2008, 21:48:30 »
Start
Run
then
ipconfig /renew
then
ipconfig
yep..check this Mike and post the result..
and here I find somethin
http://www.techsupportforum.com/microsoft-support/internet-explorer-forum/236094-solved-internet-explorer-not-working-vista.html
« Last Edit: 13 November 2008, 21:48:59 by cem_devecioglu »
« Reply #29 on: 13 November 2008, 21:52:25 »
Start
Run
then
ipconfig /renew
then
ipconfig
Tried that and at the end the right numbers come up, still not working though. :-X :-X :-X :-/
Pages: 1 [2] 3 4  All   Go Up
