Author Topic: Where can I obtain....  (Read 2388 times)
Re: Where can I obtain....
« Reply #15 on: 17 November 2008, 11:17:36 »
I take it the wheelbearing torque doesn't need to be that specific then, as long as it's effing tight? ::)
In seriousness, I would always use a new nut and, if you can't measure the torque accurately, torque it up to the maximum you can measure and add an extra "grunt" by feel.
The nut needs to be locked somehow, hence always needing a new one. Sometimes they are just locknuts, sometimes they need to be staked into a groove in the thread.
It's not specific in that it doesn't affect the bearing with a modern setup, but only in that a wheel falling off can ruin your day somewhat.
« Reply #16 on: 17 November 2008, 11:21:43 »
Every bearing/hub I have bought has come with a new nut
« Reply #17 on: 17 November 2008, 11:24:28 »
Anyone fancy a front wheel bearing day ::)
« Reply #18 on: 17 November 2008, 11:29:36 »
terribly sorry old boy, I am a little tired....to easy a job....why do you have some failed ones to do then?
« Reply #19 on: 17 November 2008, 11:42:33 »
A bit of a rumble on tractor, audible above the engine ;D
What I lack is a big enough bar on the end of a 1/2" drive strong enough...
« Reply #20 on: 17 November 2008, 11:55:49 »
Me and Loo Knee did a couple last Jan, it only took about 1/2 hour each side :y
« Reply #21 on: 17 November 2008, 11:58:11 »
Yeah, Mr DTM did one on MV6 a couple of years back, really quick job...
