Author Topic: Cambelt or chain  (Read 1557 times)
Jaseb70
  • oswestry
Cambelt or chain
« on: 17 November 2008, 12:56:51 »
Hi Im not mechnanicaly minded, I own a year 2000 2.5 TD CD Manual with a BMW engine in it. Will it have a Cambelt Or Camchain??
Thanks
Jase
Markie
  • Lanarkshire, Scotland
    • RS4, BMW X5, Range Rover
Re: Cambelt or chain
« Reply #1 on: 17 November 2008, 12:59:00 »
Chain driven i believe...
« Reply #2 on: 17 November 2008, 13:01:19 »
Yep, chain :y
« Reply #3 on: 17 November 2008, 13:02:01 »
Most definately a chain.
Jaseb70
  • oswestry
« Reply #4 on: 17 November 2008, 14:53:15 »
Thanks very much I hoped for a chain.
« Reply #5 on: 17 November 2008, 14:55:24 »
LOL, I'm gutted my 2.5TD has a chain, much rather it was a belt.  Chains have too many disadvanatges, and on this particular lump, a real bitch to change.
Markjay
  • London
« Reply #6 on: 17 November 2008, 15:49:09 »
Yes, but at least chains usually rattle before they snap... so you get some head-up that something is not quit right. Belts go in a second... I know that with the Omegas its the tensioner that goes (mine went when the car was exactly 4 years and one month old), but I fubared a 1.8 Ford Diesel engine when working for a company whose owner did not believe in servicing. The belt snapped when I started the engine and it was wrecked beyond repair. The point is that the car ran fine just prior to that, not a clue that something was about to give....
Alas, no more Omegas....
Peter H
  • Somerset
« Reply #7 on: 17 November 2008, 16:16:39 »
Apparently when the Jaguar V12 was being designed in the '60's Walter Hassan was considering a belt drive for the cams, but decided against it because you can only drive off one side of a belt, but both sides of a chain.  Boy am I glad he needed to drive the distributor jack shaft with the chain! ;D
« Last Edit: 17 November 2008, 16:17:35 by Peter_H »
Bread and water can so easily be tea and toast!
amigov6
« Reply #8 on: 17 November 2008, 19:16:36 »
Ford 1.8 denzils were fubared from the day they were new, Sherpa vans were quieter. :(
« Reply #9 on: 17 November 2008, 19:27:31 »
speaking as someone who owns a Ford 1.8 diesel,I would like to say that they are a perfectly good engine.
For a cement mixer. :y ;D
michael.d.s.
  • glasgow
« Reply #10 on: 17 November 2008, 20:07:26 »
as a ford mechanic , the biggest issue with the timing belts is the rocker cover gaskets . they leak into the timing casing and cause the rubber in the belt to breakdown , i've even known people to replace the camshaft valves and belt , then a week later BANG the pump belt goes taking the timing belt with it .ha ha tight fisted to$$ers  ;D
