Author Topic: Electric Oven Probs...  (Read 2338 times)
Re: Electric Oven Probs...
« Reply #15 on: 19 November 2008, 10:54:54 »
Have you been burning stuff too? We had a similar problem which co-incided with the standard of Mrs. KWs cooking not being up to its' usual exemplary level.  :'(
Turned out the nasty capillary thermostat had got a bit lazy. Set the oven to 200 C and it was actually reaching almost 300. :o New thermostat in the oven and it was fine.. Howver I think the replacement has packed up now too. >:(
Quite often there'll be more than one element doing the heating, depending on the mode selected, so could be you've had a single element fail. If it's slow on "fan assisted" mode can you try it in "conventional" mode?
I got a nice multimeter from Maplin with a thermocouple which is ideal for oven diagnostics.  8-)
LJay
  • North Wales
  • The Acrobatics Queen!
    • 3.2 - MV6 Big Blue!
« Reply #16 on: 19 November 2008, 11:09:41 »
An oven that used to take 20 mins to heat up, now takes 30-40 minutes.
What do you think is wrong?
I'm thinking replace the element, only £20.
Its quicker to go for a takeout ;)
Safer if i'm cooking too! ;D
Been there, fallen over it!
