Author Topic: One for Debs  (Read 1147 times)
Gaffers
  • NE Hampshire/Surrey
    • Ford Ranger Wildtrak
One for Debs
« on: 18 November 2008, 22:53:04 »
No doubt a quick one for the Queen of knowledge but I cant find the answer anywhere....
On the boat hull I am using glycerophthalic paint onto which I was hoping to put a layer of Epoxy to increase the protection for the paint.  After which I was going to put several layers of varnish.
My question is, will the epoxy bond to the glycerophthalic paint and will it pool like water on an oily sirface?
very many thanks in advance  :y
Debs.
Re: One for Debs
« Reply #1 on: 19 November 2008, 00:15:54 »
I would contact the paint manufacturer for advice on compatability....failing that, a test using the appropriate substrate, glycerophtalic paint and epoxy (allowing for a fully oxidised cure before applying the epoxy top-coat over the paint).
The mechanical bond twixt the paint and epoxy-matrix will be poor and the chemical bond (likely) of low compatability for long term surety.
Although on the face of it the concept is good; I would ask the paint maker first and even then think twice, as it`ll be a bugger to sort later if the combo proves unsuitable.
Personally, I`d go with just the paint and varnish and skip the epoxy element.
Are there not highly-toughened specialist marine-paints marketed for your needs? ;)
Gaffers
Re: One for Debs
« Reply #2 on: 19 November 2008, 05:26:20 »
I was thinking you might say that.  I may just have to go with several coats of varnish instead which should provide many years mainenance free trouble.
Ta  :y
Re: One for Debs
« Reply #3 on: 19 November 2008, 08:33:34 »
What, no bonus question ;D
Re: One for Debs
« Reply #4 on: 19 November 2008, 09:24:41 »
Not dissimilar to Omega ownership then. ;D
dad1uk
  • Birmingham
    • Vauxhall Zafira 2.2
Re: One for Debs
« Reply #5 on: 19 November 2008, 16:47:20 »
ok Debs, that was your starter for 10 points, the real question may follow...... if someone can think one up!  ;D
best wishes
Simon.
Debs.
Re: One for Debs
« Reply #6 on: 19 November 2008, 17:12:23 »
No conferring?  :-/
I used to adore University Challenge: back in those delightful Bamber Gascoigne days; before the sneering, 'know-nought' current incumbent assumed the chair. :-[
razzo
  • Crapital
    • 97 3.0 Elite
Re: One for Debs
« Reply #7 on: 19 November 2008, 17:12:24 »
so what would be better or more hard wearing marine varnish or 2k clear coat
amigov6
Re: One for Debs
« Reply #8 on: 19 November 2008, 17:33:59 »
No conferring?  :-/
"Incumbent" :D I love that word although Universally Challenged is more my mark!
