Author Topic: Astra van  (Read 856 times)
miggy
Astra van
« on: 19 November 2008, 17:11:28 »
Hiya chaps and chapesses
Would anyone know what could be the problem:-
Astra van diesel, the brake lights are on all the time, when the engine is switched off and the key is removed the egine keeps running. when the brake pedal is pressed the engine stops.
The brake switch is not stuck on.
I have never come across this before, could it be a faulty relay somewhere
« Last Edit: 19 November 2008, 17:11:46 by miggy »
Re: Astra van
« Reply #1 on: 19 November 2008, 17:22:27 »
you need to sort out your avatar  ;)
amigov6
Re: Astra van
« Reply #2 on: 19 November 2008, 17:25:22 »
Must be an obscure fault if that would help!!! [smiley=2vrolijk_08.gif]
miggy
Re: Astra van
« Reply #3 on: 19 November 2008, 17:27:18 »
Thats why i put it in general chat as it aint Miggy related....... :D
« Last Edit: 19 November 2008, 17:27:39 by miggy »
miggy
Re: Astra van
« Reply #4 on: 19 November 2008, 17:28:14 »
Re: Astra van
« Reply #5 on: 21 November 2008, 16:42:42 »
Just a thought... When I had my Astravan if I had some item plugged into the ciggie lighter it did something similar... Can't remember what was plugged in though ::) ::) ::)
It's an odd one... Sounds like something is powering up the ignition system in some respects
