Author Topic: Is this a bit overpriced  (Read 2481 times)
STMO123
Re: Is this a bit overpriced
« Reply #15 on: 24 November 2008, 14:15:41 »
So.....somebody make an offer ;D
£500 tops its done 203k miles  :o
Well, the 'make an offer' box is there........... ::)
« Reply #16 on: 24 November 2008, 14:15:57 »
I thought it was a tad over priced, just did not want to sound to sarcastic in case owner was on here  ;D
Mike
Hadn't thought of that ::) ::) :-[ :-[
Sorry if I've offended the owner but just speaking my mind! :y :y
Martin_1962
« Reply #17 on: 24 November 2008, 17:10:15 »
That LPG conversion probably has "straws" on the back of the nozzles, which reach down into the intake passages from the plenum to inject the gas down by the valve, so not as bad as it looks.
Better, IMHO, to drill and tap the manifold but it can be done that way and it saves removing the manifold.
Romano System N that is what mine had and I reused
Martin_1962
« Reply #18 on: 24 November 2008, 17:11:02 »
1) It IS very overpriced.
2) I wouldn't fit a cylinder tank in an estate!
3) That's a professional installation???? Injecting the LPG into the plenum is a big no-no! It makes it virtually the same as a mixer system! I reckon that's probably why it's going!  :o :o
God I'm so glad I did my own installation... I've only seen 1 professional installation up to the same standard as mine... Entwood's :y :y
AutoGas WorldWide straws - work quite well but removing the plenum is a PITA
Martin_1962
« Reply #19 on: 24 November 2008, 17:12:14 »
True...  But it looks bloody awful and not worth the money he paid. I would have gone ape if that was what was done to mine! That's why I went DIY and then you get what you're proud of, and something which doesn't look like it was fitted by a monkey! Straws are not an ideal method of injecting LPG... Just a compromise!!
I'm just glad you were willing to do my manifold because that was the only bit I wasn't 100% confident with :y :y :y
Agreed on all counts... and I hope he at least took the plenum off to drill and tap it. :o
He is dreaming with that price though. Look at the mileage!  ::)
You have to to install the cut injector cabling - that said I am thinking of moving to jets in the manifold but the flow on straws is quite good
Martin_1962
« Reply #20 on: 24 November 2008, 17:14:34 »
FIlter - that is where the evaportaor is
« Reply #21 on: 24 November 2008, 17:33:44 »
Mike
How dare you all take the piss out of my car....it is worth every penny. ;D ;D :D.....Seriously though.....not in the real world as regards price.....done over 200,000 miles to boot. :-/ :y :y :y
« Reply #22 on: 24 November 2008, 18:27:09 »
Ahh, yes.  :-[
Keep meaning to remove all the piggy-back connectors from under my plenum and make up a new loom with a single multi-way plug to connect it to the LPG side.
TBH, if if runs OK on them I wouldn't worry. I can't imagine there's a lot in it, TBH. I read somewhere that it's better to inject vapour across the airflow rather than with it (as you would with a liquid fuel) to promote better mixing, so that might give the manifold nozzles a slight advantage but we're splitting hairs really.  :-/
doog
  • Alloa Central Scotland
« Reply #23 on: 24 November 2008, 18:34:25 »
Trying to make sense of paying £1800 for a conversion and then only doing 4k miles... I'll have a pound that it doesn't run right.
Oh... And the MAF will be shot soon to because he's fitted an oiled K&N ::) ::)
why would that kill the MAF?
Doug
me at kick boxing
« Reply #24 on: 24 November 2008, 18:42:14 »
Doug
Oil from the filter will coat the sensing elements of the MAF. Not good to use a K&N with a MAF unless you're very sparing with the oil.
