Author Topic: Computer/TV questions for you experts ...  (Read 2326 times)
« on: 29 November 2008, 21:44:17 »
My TV has "extra" inputs for either
a) 3 mini-jack plugs labelled Video, Audio (L), Audio (R)
or
b) S-Video  (looks a bit like a keyboard socket !!)
My Laptop has a 15 pin "D" socket and can be switched to operate an external monitor.
Questions :
1) Is there any way the laptop output can be connected to the TV sockets  or are the signals totally incompatible ??
2) TV also has a spare SCART socket on the back ... can this be used for computer input ??
Any ideas gratefully accepted  :)
Re: Computer/TV questions for you experts ...
« Reply #1 on: 29 November 2008, 21:54:11 »
Normally a lappy has a yellow phono socket for video output, if so, use that and the on board speakers or take a 3.5 mm jack split to staro (2 x phono) and plug the jack into the headphone socket on the lappy.
Then plug the yellow phono from lappy to TV (requires 75ohm cable I believe) the the red and white phono pick up the sound off the head  :yphones lead
« Reply #2 on: 29 November 2008, 22:19:45 »
No phono sockets on the lappy (its quite old) just the 15-pin D connector  :(
Edit .. further research (looking harder  !!) has just shown I have a 4-pin S-Video Output on the lappy (I thought it was another mouse/keyboard socket !!) and a 4 pin S-Video + 3 RCA on the TV
Does this mean I can connect the 2 S-Video together to run the lapy into the TV ?
« Last Edit: 29 November 2008, 22:27:06 by entwood »
Taxi_Driver
« Reply #3 on: 29 November 2008, 22:24:16 »
Unless your lappy has as Skruntie suggests.....then in a word....no
Well.....not easily anyway.
Easiest way would be to use the scart connector.....connected to 15 pin socket of your lappy....BUT there has to be a converter......ie diy manufacture.....or about 80squid to buy last time i looked quite a while ago.
Your tv wants a composite video input......your lappy 15 pin socket gives out VGA....
Try searching the interwebby for VGA to SCART convertors, if your handy with a soldering iron......im sure your'll find how to make a convertor  :y
« Reply #4 on: 29 November 2008, 22:24:48 »
The 15 pin "D" is basically an RGB output, although some video adaptors can output S video through these, and you need an adaptor to turn it back into a "mini-din" "keyboard plug".
RGB can be fed into a SCART socket (often only one of them if the TV has more than one) but you will need a circuit to combine the sync signals into a composite sync signal instead of separate H and V signals. Secondly, you need to make sure the laptop can output a scan rate that the TC will support. Most monitors scan much faster and accept a wider range of scan rates than a TV.
In short.... Not without a fair bit of messing about.
« Reply #5 on: 29 November 2008, 22:28:39 »
As I was posting I found some more info which I edited into an earlier commant .. for simplicity I'll repeat it now ..
.....  further research (looking harder  !!) has just shown I have a 4-pin S-Video Output on the lappy (I thought it was another mouse/keyboard socket !!) and a 4 pin S-Video + 3 RCA on the TV
Does this mean I can connect the 2 S-Video together to run the lappy into the TV ?
« Last Edit: 29 November 2008, 22:29:43 by entwood »
« Reply #6 on: 29 November 2008, 22:33:31 »
Should do. Might need to play around with the video settings to get it working.
nabsim
  • High Peak
« Reply #7 on: 29 November 2008, 22:35:51 »
If your lappy has USB you can get various usb to different video convertors. We use a USB to DVI convertor to give a second screen on mini itx boards.
Have a look at this, think this will have the connectors you want
opps, forgot the link
http://www.amazon.co.uk/Composite-S-Video-to-VGA-Converter/dp/B001ISZ9FY/ref=sr_1_5?ie=UTF8&s=electronics&qid=1227998016&sr=8-5
« Last Edit: 29 November 2008, 22:36:10 by nabsim »
MickAP
  • South Derbyshire
« Reply #8 on: 29 November 2008, 22:36:46 »
I have connected my laptop to TV via the s-video connections.
You need to enable the laptop diplay settings to show on an external monitor I think.
Picture quality not great on my TV as it is the old style screen, not LCD or plasma.
Mick
« Reply #9 on: 29 November 2008, 22:50:22 »
Thanks for the inputs ...  really cleared things up ..  :y :y :y
So ..
if I connect the lappy S-video to the TV S-Video using one of these ...  http://www.ebuyer.com/product/137233
and the lappy sound to the TV phono using one of these .. http://www.ebuyer.com/product/124532
It has a fair to middling chance of working once I learn how to set it up ???
Thanks from "Home Entertainment for Dummies"  :)
« Reply #10 on: 29 November 2008, 22:58:04 »
So ..
They should do the OK :y :y
« Reply #11 on: 29 November 2008, 23:01:57 »
Magic .. for the sake of less than £10 ... ordered .. :)
This BTW, is so SWTSMBO can watch downloaded DivX stuff on the TV not the computer, as its uncomfortable and too small .. :(
I can't be bothered to keep converting DivX to DVD just so she can watch Prison Break before it hits UK TV .. !!!
Martin_1962
« Reply #12 on: 30 November 2008, 21:31:01 »
I use Tversity media server to copy to the PS3 then watch on that
« Reply #13 on: 30 November 2008, 21:40:59 »
Cough resistor network cough............and it works although its  bit dependent on the PLL cicruits in the TV.
To be totaly correct a handful of XOR gates and a transistor or two (transistors only required for analogue sync and not TTL)
« Reply #14 on: 30 November 2008, 23:19:15 »
Whats a PS3  ? ...  :)
Speak english PLEASE .....    :)
Once apon a time I couldn't even spell inginear .. and now I is one ...  :)
« Last Edit: 30 November 2008, 23:21:23 by entwood »
