Author Topic: XP keeps shutting down  (Read 2933 times)
Dazzler
  • Haverhill, Suffolk
« on: 01 December 2008, 15:52:16 »
Hi folks...XP trouble again.... >:(
It keeps shutting down when in the middle of use.
I have down an agrevated reboot 3 times now but still it does it.....
Any ideas????
Re: XP keeps shutting down
« Reply #1 on: 01 December 2008, 16:18:25 »
The PC is just rebooting itself?
Check CPU and case temperature - could be a hardware fault  :-/
« Reply #2 on: 01 December 2008, 16:22:44 »
yep..check the cpu cooler ..if dirty can cook the cpu..seen many times..
« Reply #3 on: 01 December 2008, 16:24:08 »
did you add any new hardware tv card, disk etc.. ?
or installed a new software ?
« Last Edit: 01 December 2008, 16:25:44 by cem_devecioglu »
amigov6
« Reply #4 on: 01 December 2008, 16:27:23 »
I'm XP with the desktop, no probs here. Virgin Cable.
« Reply #5 on: 01 December 2008, 16:29:17 »
yep..3 desktops all xp here..
« Reply #6 on: 01 December 2008, 16:54:51 »
try this
my computer>properties>advanced tab>startup and recovery settings   -- disable automatically restart
after if possible
my computer>manage>event viewer check system logs and application logs
check errors..
« Last Edit: 01 December 2008, 16:55:57 by cem_devecioglu »
alexandjen
  • Sittingbourne, Kent
  • The Silver Surfer
« Reply #7 on: 01 December 2008, 18:13:29 »
Any ideas????
I've had the same problem recently, though I had a virus in the boot sector, lived with it for weeks with it shutting down and rebooting when it felt like it.
I was told by a friend of mine, who works in the IT industry, to take the side off the case, unplug all cards, memory chips and replace them making sure that are reseated properly...........problem cured, pc has been fine ever since.
Must have been an item of hardware that had worked loose :y
Have you moved your case lately?
Trade club card holder
Code scanner available
Dazzler
« Reply #8 on: 01 December 2008, 18:42:20 »
Any ideas????
Case has not moved for 4 years.
alexandjen
  • The Silver Surfer
« Reply #9 on: 01 December 2008, 18:58:19 »
Any ideas????
Still worth doing as apparently things can work loose with vibration of fans etc.
Pete Elite
  • Uxbridge, Middlesex
« Reply #10 on: 01 December 2008, 20:20:32 »
Any ideas????
         Hi Dazzler,
                        If you haven't moved the case for 4 years :o then you may need to give it a good dust out as it may be clogged and causing a overheating problem, i do mine regularly and have never had any problems :).
        HTH,
              Pete :y.
gwa
  • Peterborough
  • Ginger With Attitude
« Reply #11 on: 01 December 2008, 21:15:39 »
Any ideas????
         Hi Dazzler,
        HTH,
              Pete :y.
You may want to consider sending it to a museum and replacing it  ;D ;D ;D ;D ;D ;D
« Last Edit: 01 December 2008, 21:16:00 by gwa »
If it ain't fun, it ain't worth doin
MindlessJD
  • Locks Heath, Hampshire
  • Mac Maniac
« Reply #12 on: 01 December 2008, 21:17:04 »
If you have installed any software recently, that could be the problem. Try a system restore.
General House Repairs in South Hampshire
-- http://www.lfdennett.co.uk --
SteveMJ
  • Hertfordshire
« Reply #13 on: 01 December 2008, 21:57:36 »
I can't add much; except I had two random shutdowns yesterday - one after the other.
I think I'll try and de-dust (is there such a word) soon.  Also do a virus scan AVG by the way.
Steve
BigAl
  • Bromley, Kent
    • '07 Forester
« Reply #14 on: 01 December 2008, 22:19:49 »
Best way is take the box outside, minus the side/top a give it a good blast with compressed air and then carefully vacuum/ sweep up with a paint brush all loose clumps of dust
