Author Topic: easy, easy, easy.......  (Read 2357 times)
sir moanalot
  • fens
« on: 01 January 2007, 16:46:02 »
is there ever an easy job?
i thought id replace my tatty number plates -only 4 screws, mate up the plates drill the holes, putting the new plates on.
but... managed to change the front one easily then on to the rear, one screw kept on spinning so........ a trip back up to the flat for a torx, tailgate inner cover off pliers on the insert and  the rest of the job was completed.
next "easy" jobs are- find out why my r/hand full beam isnt working!! (bulb/fuse /connector ok).
see why my heated seat isnt working.
see why my aircon isnt coming on.
see why my screen mists up as if i am participating in an "in car orgy".
see why my seat does not go up or down.
see why my passenger seat does not go up or down.
see why my headlight switch is not illuminated.
see why my wing mirror lights are intermittent..........................
STMO123
Re: easy, easy, easy.......
« Reply #1 on: 01 January 2007, 17:01:37 »
And what are you doing after Wednesday Tone? ;D
« Last Edit: 01 January 2007, 17:01:55 by STMO123 »
« Reply #2 on: 01 January 2007, 17:02:20 »
:-? Which lights are they?  :-?
Timbuk
  • Telford
  • owned a Datsun 120y once!
« Reply #3 on: 01 January 2007, 17:06:29 »
Early Meegas have a small LED on th mirror switch that lights up when you put your HRW on, could be this one?
« Reply #4 on: 01 January 2007, 17:08:51 »
Some very early ones have yellow light when mirror heaters on...
« Reply #5 on: 01 January 2007, 17:22:21 »
Oh! Like Senators then. I'd have to go & look at mine  :-[ .......
Just braved the elements ---- and no I don't. Neither does an Astra G (same switch)
sir moanalot
  • fens
« Reply #6 on: 01 January 2007, 17:24:36 »
thats one problem solved then!!!!
« Reply #7 on: 01 January 2007, 17:25:20 »
I think they only had the light up to around 96/97...
sir moanalot
  • fens
« Reply #8 on: 01 January 2007, 17:29:34 »
lets hope i can fix the other problems by warming up my butt on the computor chair.......
