Author Topic: An interesting Cam cover gasket change yesterday!  (Read 2103 times)
« on: 12 December 2008, 08:31:50 »
I completed the cam cover gasket change on the 2.5V6, which did not get done during Mr Loo Knee's christmas bash, yesterday.
Found a few issues
  • A bolt missing out the throttle body
  • Breather pipe connection snapped off the back of the breather bridge (an aradite attempted repair had been tried)
  • One bolt missing from the passenger side cam cover and the remains of the bolt snapped off in the cam bearing.
  • Bosch plug leads not long enough!
So.....beware Bosch plug leads, they dont fit to well and the longest one is not realy long enough!
The breather bridge was fixed by drilling out the bridge with a 6.5mm hole to insert the remains of the connection (first applying some solvent to create a welded joint). This gives a shorter connection but, is very strong and easy manageable
Cam bearing was removed then the bolt remains removed....a suitable replacement bolt was then found, cut down to size, finished and fitted.
So, an interesting one and the above pushed the job time out to a total of 3hours!  :o
All was good once it was started  :y
« Last Edit: 12 December 2008, 08:33:12 by Mark »
Re: An interesting Cam cover gasket change yesterday!
« Reply #1 on: 12 December 2008, 08:36:31 »
On top of that little lot, I also managed to get two front springs and a CV joint changed on a Corsa.
The laser changed on the NAV unit of an NCDC for SP_3.2, this also worked fine.
Went to see 'the little lad' in his christmas play....in the starring role as joseph (which was very nerve racking given what he does sometimes!).
Feel a bit tired today!
« Reply #2 on: 12 December 2008, 12:01:55 »
Would people be interested in an NCDC mechanism exchange service to correct failed pickups on the nav sections?
« Last Edit: 12 December 2008, 12:02:09 by Mark »
« Reply #3 on: 12 December 2008, 12:15:46 »
Found a few issues
I would like to add that the previous issues had nothing to do with Loo Knee or myself ::)
« Reply #4 on: 12 December 2008, 12:21:55 »
Lol....how did you find the Bosch plug leads that you used on that day....good or poor?
« Reply #5 on: 12 December 2008, 12:27:00 »
I've fitted two sets now, one to my own and the ones at Loo Knees a couple of weeks ago and they were fine. I bought mine off Ebay and I paid about £30 I think.
« Reply #6 on: 12 December 2008, 12:28:57 »
Interesting....I wonder if they were real Bosch ones....the longest lead was to short (fortunately I had a 19K mile genuine one to replace that one with) and the sections that attach to the plug sat much to high with teh leads coming off at a poor angle.
Build quality seemed ok but the fit was crap
Martin_1962
« Reply #7 on: 12 December 2008, 12:35:48 »
How do you manage all this?!?!
I am going to park outside of your house  ;D
« Reply #8 on: 12 December 2008, 12:36:46 »
I would say that the sections that fit to the plugs are not as good a fit as genuine, you could pull them off without the use of the orange plug lead tool.
« Reply #9 on: 12 December 2008, 12:37:04 »
Needed to clear some jobs so I can start breaking working on Mick Dundees car.
« Reply #10 on: 12 December 2008, 12:38:00 »
Did they fit comfortably in the holes though, these seemed loose and sat 5-10mm to high?
« Reply #11 on: 12 December 2008, 12:41:46 »
Right, going to check the Bosch part numbers:
B143 seems to be the ones I fitted yesterday.....yet B162 look MUCH better
« Reply #12 on: 12 December 2008, 12:42:55 »
They were a solid fit on top of the plug but the diameter at the top of the lead that seals against the camcover was slightly too small
« Reply #13 on: 12 December 2008, 12:47:19 »
These were to small, and to long!
« Reply #14 on: 12 December 2008, 15:00:06 »
I think that will be an excellent service, but possibly lost in this thread ;)
