Pages: 1 2 [3]  All   Go Down
Author Topic: Bought one of these  (Read 8599 times)
iggy21uk
  • Berkhamsted - Herts
  • Omega Spotter -  tats gone tanning
Re: Bought one of these
« Reply #30 on: 11 December 2006, 10:57:53 »
Think the customs man owns a Vauxhall ?
[size=10]Opelscanner Can owner / Cam lock kit owner [/size] [/i][/b]
Opelscan
« Reply #31 on: 12 December 2006, 23:29:37 »
:( i have the 9pin serial cables, software and hardware, just missing the 16pin diagnostic plugs.
As soon as i have them they will be sent. :)
Markjay
  • London
« Reply #32 on: 13 December 2006, 00:09:47 »
No offence meant to Opelscan or any other code reader, but after seeing TB's Tech2 I started saving up for one....
Alas, no more Omegas....
Opelscan
« Reply #33 on: 13 December 2006, 00:38:25 »
none taken m8. I have found a bloke with 1 but it has the isuzu software on instead, he know im a vauxhall fan and and hoping to borrow it, or even buy it just to compare the units. The guy who programs the software says it is possible to do everything that the tech2 can,but needs to add it to the software, and as you can imagine thats alot.
on many of the updates what people have requested have been added.
Good luck with the saving up, as i too have been saving for a long time for tech2.
« Last Edit: 13 December 2006, 00:39:46 by Opelscan »
bob.dent
  • Hertfordshire
  • Drives better than an Omega
    • Mondeo 2.0TDCI Estate
« Reply #34 on: 13 December 2006, 10:27:35 »
Yes i do know its a BMW, but to be honest, i know jack s**t about web design, so i used a template to get me up and running quickly. Maybe if you are good at it you would be so kind to offer your services and change it for me. Obviously i will pay you for your troubles.
Hi Chris, you could try sending supermop (my son) a PM as he's pretty good with web design and I'm sure he could help you out with your site.  :y
« Reply #35 on: 14 December 2006, 19:38:30 »
Yes I would like to compare one against my Tech2, only cannot justify the cost when I already have the real thing...
Anyone who has bought one fancy lending it to me for a week or 2 ;)
iggy21uk
« Reply #36 on: 19 December 2006, 20:23:44 »
I've be told sent to me yesterday, after cable delay nearly,  broke the postmans fingers this morning - not yet got here.
I thinking of testing it on the turkey - might be able to make it fly?  ;D ;D
iggy21uk
« Reply #37 on: 20 December 2006, 11:53:20 »
Well the Opel scanner has arrived could not connect and read codes via usb
adapter.
Connects and working via serial port.
 ;D :D :y
Just thought may need to change the USB Comm port number?
« Last Edit: 20 December 2006, 11:55:38 by iggy21uk »
iggy21uk
« Reply #38 on: 20 December 2006, 15:14:13 »
Trust it to arrive on a cold day  I'm frozen :-[
Seem to do every think it says on the tin
Even manged to get it working with serial to usb cable.  ::)
Now got error message . "User has unit with the wrong software to many times
unit has be disabled - contact re-seller" -em not sure I can sort that one?
« Last Edit: 20 December 2006, 15:28:55 by iggy21uk »
« Reply #39 on: 20 December 2006, 18:01:51 »
oh dear....
iggy21uk
« Reply #40 on: 29 December 2006, 20:33:24 »
Update - The software is matched to the unit so is not easy to copy.
But I seem to have a problem, either the software has the wrong serial number or scanner has the wrong
serial programmed in it ???
But it did work. Read gearbox, electric seat memory & more
Even got it to work via usb to seial converter. Will post more info when I get the problem sorted.
I know the guy will be placing an order in the new year.
iggy21uk
« Reply #41 on: 04 January 2007, 15:35:01 »
Software problem sorted. It works but  does not like the USB  to Serial converter
Going to try pcmcia - serial converter - ordered one from ebay from Hong Kong £13.00
If that don't work may buy a usb to serial from here www.ftdichip.com its designed in the UK
instead of the taiwan chip my one has now.
Built in the software is some 'blackbox' software that makes a log files
which shows why the program has a problem
I sent the log file to the guy he has looked at the files shows its the USB to serial giving me trouble
Quote "We  can  not  guarantee  proper  work  with  such  adapters, since our interface requires  continuous  asynchronous data exchange, which USB-COM adapters are not able to provide 100%"
It work for a while then hangs.
Pages: 1 2 [3]  All   Go Up
