Author Topic: RE: Coolant change & flush  (Read 1801 times)
kjon51
  • Oldsville - East Sussex
« on: 04 January 2007, 15:59:37 »
Thanks for the great new maintenance guide tunnie & TB.  :y
Quick Question - I siphoned about a litre out from the header tank 'cos I was going to top up with a litre of new, neat antifreeze. When I saw what had come out it looked good & fresh & pink & clean, (if you see what I mean). Is it safe to assume that my coolant is OK for another winter without further test or topping up?
Cheers,
John
Re: Coolant change & flush
« Reply #1 on: 04 January 2007, 16:21:24 »
Cheers,
John
Yep sounds good, as per my piccys on the maintenance guide. Pink is good  :y
« Reply #2 on: 04 January 2007, 16:29:25 »
Cheers,
John
only true way to tell if right amount of antifreeze in water is hydrometer...
« Reply #3 on: 04 January 2007, 16:38:22 »
The only safe way is to change it......over time the anti corrosive additives degrade, this may well not affect the colour until some thing starts to get 'eaten away'!
« Reply #4 on: 04 January 2007, 16:43:52 »
going to do the mv6 in next week or so....  ....I have a cleaner expansion bottle as well that I may fit at same time
x25xe
  • Hayes, Middlesex
  • Avater removed due to size
« Reply #5 on: 04 January 2007, 17:30:49 »
When I changed my coolant last summer, I ordered a new expansion bottle as there were cracks around the filler neck and I did not want to take any chances.
With a new bottle filled with the correct concentration of Red antifreeze (50/50 mix) it does look rather good in the engine bay!
I thought I had a pic of this, but can't find it.
Recommend fitting a clean bottle though.
