Author Topic: LPG Tank query  (Read 1251 times)
LPG Tank query
« on: 21 December 2008, 18:53:45 »
Moving an LPG tank today, I think I must have put it down a little awkwardly, as there is now a small dent in the end of it, which wasn't there before.
Should I bin the tank? If it were internal there would be no question, but It's externally (chassis) mounted, and in reality, I'm wondering if it will cause a problem.
I'm also considering getting a third, larger tank for the boot, to accompany the twin torpedos. Anyone know a good supplier, for a 200litre bomb? ;D
Cheers
James
STMO123
Re: LPG Tank query
« Reply #1 on: 21 December 2008, 18:54:40 »
No
Re: LPG Tank query
« Reply #2 on: 21 December 2008, 18:55:14 »
No
Nice to see you on form tonight Grandad...
STMO123
Re: LPG Tank query
« Reply #3 on: 21 December 2008, 18:56:23 »
No
That's no way to talk to the man who introduced you to your first facelift. ;D
Re: LPG Tank query
« Reply #4 on: 21 December 2008, 18:56:40 »
If the dent's well away from the valve mounting or any welded seam I'd say it'll be OK.
STMO123
Re: LPG Tank query
« Reply #5 on: 21 December 2008, 18:57:20 »
It'll be OK James..........BOOM!  OOPS. ;D
« Last Edit: 21 December 2008, 18:57:31 by STMO123 »
Re: LPG Tank query
« Reply #6 on: 21 December 2008, 18:59:51 »
Yep - it's a good couple of inches from the weld :y
Re: LPG Tank query
« Reply #7 on: 21 December 2008, 19:23:19 »
Maybe it'll "pop out" when you fill it up? :-X
Take some spare undies in case it does.
Dazzler
  • Haverhill, Suffolk
Re: LPG Tank query
« Reply #8 on: 21 December 2008, 19:46:23 »
See if you can find someone to pressure test it to see.
Maybe try and have a word with Tylo.
HerefordElite
  • Hereford
  • Welcome to the Shire
Re: LPG Tank query
« Reply #9 on: 21 December 2008, 22:01:11 »
don't suppose you know anyone with a pressure testing water tank? we had one at my last place for testing compressor castings until one blew at 60 bar and took out the rather windows ::) ::) ::)
seriously i'd get it tested if you can and it may 'pop' out like Kev says ;)
