Author Topic: Fitted a new sink today  (Read 833 times)
Martin_1962
« on: 31 December 2008, 18:56:35 »
We had new stainless steel appliances last year, and the current sink was leaking, stained, and the tap was worn out - also white plastic - looked yuk.
So today I fitted a new stainless 1.5 bowl sink with tap.
Fitted service valves as well.
Just got to fit a U bend - old drain pipework has now been cleaned.
Old sink had rounded ends and was shallower, had to cut out corners and about 20mm along the back - quick trip out for better blades.
old sink was slightly wider - had to chop out part of the cupboard as the 0.5 bowl was fouling on it
I had worked out the drain prior and had soldered up the pipework ready - just had to cut to size and connect to the stops.
« Last Edit: 31 December 2008, 18:57:01 by Martin_1962 »
Page created in 0.011 seconds with 18 queries.
