Pages: 1 2 3 [4] 5  All   Go Down
Author Topic: Speed Test  (Read 6890 times)
Re: Speed Test
« Reply #45 on: 30 December 2008, 21:38:00 »
2 days ago AM whilst dowloading on Max Bandwidth.
Tonight during peak user time.
« Last Edit: 30 December 2008, 21:38:27 by skruntie »
Re: Speed Test
« Reply #46 on: 30 December 2008, 21:50:42 »
tested 8.47pm tonight.
You now want to compare that with an off peak one, to see if there is much of an improvement
will try again in the a.m. if i remember.
was suprised to see it that high tbh... :o
Re: Speed Test
« Reply #47 on: 30 December 2008, 22:11:52 »
Now:
Yesterday morning:
Pretty similar, implication is line is now limiting factor, though NTL use those poxy proxies which help no end with speed tests.
What sync speed are you getting?
Re: Speed Test
« Reply #48 on: 30 December 2008, 22:13:42 »
You couldn't have been downloading at max bandwidth, and still getting that sort of throughput ;)
Either the download paused during test, or the download was using little bandwidth ;)
Re: Speed Test
« Reply #49 on: 30 December 2008, 22:43:26 »
I am no internet specialist, I just repoted what I saw.
Re: Speed Test
« Reply #50 on: 30 December 2008, 22:53:16 »
if you are downloading at max bandwidth (ie, no spare bandwidth), you can't get a 5Mbps down the line as well ;)
So something, unsurprisingly, is telling you a load of BS - hence why these speedtesters mean jack...  ...only one that is useful is the BT Speedtester, loging on via the special logon to bypass the ISP.  That is when the speedtester is not doign a DoS on BT's own firewalls  :-X
Nickbat
Re: Speed Test
« Reply #51 on: 30 December 2008, 22:58:53 »
Not too wonderful.  :(
« Last Edit: 30 December 2008, 22:59:28 by Nickbat »
Re: Speed Test
« Reply #52 on: 30 December 2008, 23:00:17 »
found a similar version, which includes your postcode...
http://www.broadband.co.uk/broadband-speed-test.jsp
which reported,
Your local exchange is Reading South and the maximum theoretical speed achievable on your line via ADSL Max is 3.42Mb which is 189 percent faster than this test shows you are getting.
Re: Speed Test
« Reply #53 on: 30 December 2008, 23:03:31 »
Looks like the kids are starting to head off to bed.
Re: Speed Test
« Reply #54 on: 30 December 2008, 23:05:50 »
We would be very happy with that mate  :-X ;)
Re: Speed Test
« Reply #55 on: 31 December 2008, 13:02:38 »
tested 8.47pm
and again 12.27a.m. weds 31
and again 12 hours later, 12.50pm weds 31
not much variation with peak and off peak, would suggest a fault? Although the speed is capped to reduce errors and then the router slowing to the point we have to unplug it to reset.
Re: Speed Test
« Reply #56 on: 31 December 2008, 14:17:51 »
tested 8.47pm
That shows that its less likely to be exchange contention or ISP issue, but local line.
As per all advice, does it improve if you have it purely in master socket, with all house wiring disconnected? Does a better quality router help?
Re: Speed Test
« Reply #57 on: 31 December 2008, 17:23:40 »
tested 8.47pm
Ok, will plug router in main socket again as the next test, when ive moved the xmas tree, coffee table, setee, so that i can get at the chest of draws, to access the plug, to unscrew the the face plate, to get to the master socket(?) and plug the rather thing in again for the 5th time to find its exactly the same....?  :-X
Mite try another router first i think... :y
LouisCorney
Re: Speed Test
« Reply #58 on: 31 December 2008, 19:08:55 »
Just now:
robbo299
  • luton, beds
Re: Speed Test
« Reply #59 on: 31 December 2008, 20:14:20 »
Download.. 19.54 Mbs ( 2.44MB/s)
Upload...... 737kbps  ( 92.1kB/s )
Ok with that. :y
Pages: 1 2 3 [4] 5  All   Go Up
