Pages: [1] 2 3  All   Go Down
Author Topic: my second car  (Read 4171 times)
Marie
    • 2ltr LPG Estate
my second car
« on: 01 January 2009, 22:52:01 »
well i have just been given a family car. well my grandad has had it from new.
its a rover 216 si auto. (1998) its 3 door  petrol 1589cc white. its only got 60,327 on the clock. its got 12mths tax (well will have tomorrow) and mot is due on the 23rd.
grandad gave it to my old gits last year and they have left it on the drive for 12mths drove it 12 miles since they moted it last year.
its tidy just need the engine overhalling as half the history is missing. :( including the service handbook  >:( so i have no idea whats been done when) all i know is the cam belt was done in jan 2002 at 23,711 miles cos there is a sticker under the bonet. i rang rover and they said its 60000 miles and 5yrs. so needs doing.
does anyone know of a rover forum that is a good OOF so i can get some well needed advice? and some where to get parts?
I have got to drive it home tomorrow ( carefully and slow) but then its been left on the drive untill such time i can do some work on it asap.
the cam cover looks like its leaking, i want to do the cambelt, maybe the headgasket as i dont know its interval, full service. just a dam good going over. their was mould all over the inside of the car, yuck and the batt was dead as a do do.
i recon i am looking around £200 - 250 to do all the work on it.
Re: my second car
« Reply #1 on: 01 January 2009, 23:49:19 »
Darn! Gave away my K series cam locking set, although they should only cost pennies. I assume it is a K series as something in the back of my mind tells me that the autos had the Honda engine a bit later?
Cam belt change was straightforward, IIRC.
HGF is common, of course, but not sure I'd do it as a matter of course. A coolant change would be worthwhile, though, and check for sludge in the header tank.
Don't recall any cam cover gasket issues but a mate of mine had one that sprung an oil leak from the head gasket IIRC.
Re: my second car
« Reply #2 on: 01 January 2009, 23:49:57 »
I have a K series locking kit  :P
Re: my second car
« Reply #3 on: 01 January 2009, 23:51:41 »
Kev - I think the later "bubble shapes" were all K series - with the older (Up to L reg) being the Honda varient - could be wrong!!
Marie
    • 2ltr LPG Estate
Re: my second car
« Reply #4 on: 01 January 2009, 23:53:50 »
it is a K series engine. the front of the block was covered in gunk which looked like it was coming from the rocker gasket.
its just a bit dunting looking at it as i have never worked on a rover and dont know much about them. bit like when i started on OOF, now i am hapy to do most things! :)
Marie
    • 2ltr LPG Estate
Re: my second car
« Reply #5 on: 01 January 2009, 23:55:15 »
do you really where did you get it from and is there any tools you dont have!!!!! ;D ;D ;D
Re: my second car
« Reply #6 on: 01 January 2009, 23:57:30 »
Well, I don't have a P**is pump, but I don't think that's a "tool" by car standards, and is not something I would need to use  ;D ;D
In all seriousness, the K series locking kit is pennies - but necessary!
Re: my second car
« Reply #7 on: 02 January 2009, 00:09:26 »
Good grief did I just say that - I think it's time to put down the festive cheer and retire to bed   :-X  ;D
Re: my second car
« Reply #8 on: 02 January 2009, 00:14:47 »
Saved by the word filter to a certain extent but we know what you're trying to say....
Tunnie loves you the way you are. :-X
Re: my second car
« Reply #9 on: 02 January 2009, 00:17:49 »
Oi you... I put those stars in, not a peice of software. I have some dignity ;D ;D
In all seriousness... probably best I compose a sensible reply tomorrow, now.... :y ;D
Re: my second car
« Reply #10 on: 02 January 2009, 08:06:15 »
I would not drive it until its had a brake service at the very least.......
Marie
    • 2ltr LPG Estate
Re: my second car
« Reply #11 on: 02 January 2009, 09:04:36 »
i have had a good look at the brakes and they seem ok, they will have a good going over when i get it home.
what else would you recommend i do to it.....
Re: my second car
« Reply #12 on: 02 January 2009, 09:31:03 »
That age it will be K series, and I have a locking wedge, though possible cheaper to buy one than post - Draper one (K16) is under a fiver from most places.
Being K series, pay mega attention to coolant.  When you refill (I use Vx Red in hers) remember there is a bleed screw on transfer pipe, just to right of block. Is it dizzy, or 2 DIS setup, probably later at that age.  Worth checking the plugs, either way, as minor misfires may also be a factor in the HG failures.
Other than that, fluid and filter change, and flush the brake fluid, and clean up front calipers and rear drums.
Not sure what to do with auto, but I have full dealer manuals here if you're stuck.
Try http://forums.mg-rover.org/ as well
Marie
    • 2ltr LPG Estate
Re: my second car
« Reply #13 on: 02 January 2009, 09:44:36 »
cheers TB its good to know that someone else on here has one.
just cant wait to get it in the garage and give it a good going over. (inbetween work and other things etc)
ill check out the rover forum too. :)
Re: my second car
« Reply #14 on: 02 January 2009, 14:23:53 »
Hi Marie... Change the water pump when you do the cam belt and also, although it's a right PITA, the thermostat! For some stupid reason they always seem to fail in the closed position on the rover k series!!
Personally I wouldn't worry about the HG until it fails... Then make sure you fit the uprated gasket. I'm just doing an 8v K series for Mrs LD!
Other than that, just the normal routine stuff :y :y :y :y
Pages: [1] 2 3  All   Go Up
