Author Topic: In an Omega......  (Read 1272 times)
Phil
In an Omega......
« on: 12 January 2009, 13:02:36 »
.... the big coil thing is a shock absorber and the long metal (black or yellow) pipe type thing is a damper.
This is because the spring 'absorbs' the shock (therefore a shock absorber), and the other bit 'dampens' the bounce and re-bound (hence a damper).
Right or wrong??
Its also different in 'some' other vehicles i.e. off road vehicles?
Discuss  ;D
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
Re: In an Omega......
« Reply #1 on: 12 January 2009, 13:35:38 »
I'll say the round window.... Are you having a bad day Phill?
« Reply #2 on: 12 January 2009, 13:39:45 »
The spring does not absorb anything, it merely stores the energy which it will then re-release.
Its the job of the shock absorber to absorb the energy (and get hot as a result!) which it does by damping the spring and/or wheel movement.
Hence a shock absorber is also called a damper and the spring is well a spring!
vauxfan2k
  • Western Isles
« Reply #3 on: 12 January 2009, 13:40:48 »
yeah, a spade is a spade  ;D
Andyb
  • Lincoln
« Reply #4 on: 12 January 2009, 14:59:35 »
you cant say that its a digging implement  :y
