Author Topic: Astra EML 52 plate 16v 1600cc  (Read 2581 times)
Martin_1962
Re: Astra EML 52 plate 16v 1600cc
« Reply #15 on: 08 January 2009, 11:29:29 »
Time we brought back points............ ::)
[size=18]NOooooooooo!!!!![/size]  :y  :y  :y
Anything  but those bloody things! They kept their setting for the first  ...... 100 yards cos either they wore where they ran against the cam or the faces of the points spiked! Getting rid of them on my Manta was the best thing I ever did. ;)  ;)  ;) :y :y
At least you could fix them, regularly................. ;D
I replaced a set for a friend once - not as easy as checking air gap on the distributor pick up on my Sunbeam of similar vintage
« Reply #16 on: 08 January 2009, 20:14:49 »
New generic coil fitted. So far & £75 later there's no EML .......  :-X
« Reply #17 on: 11 January 2009, 22:55:48 »
Famous last words!  :(
The bloody EML is back on ......  :'( Same codes as before 0300 & 0302 which .... if I've got the right fault codes is :- General misfire & misfire on No 2
Any suggestions would be most gratefull as I've now run out of ideas. New plugs a few weeks back & a new (generic) coil pack last Thurs less than 20 miles ago. :-/ :-/  :-/  :-/  :-/
« Reply #18 on: 12 January 2009, 04:18:19 »
wiring/connector to the pac/knock sensor?
« Reply #19 on: 13 January 2009, 18:57:08 »
No more suggestions then?  :(
Fuel rail came out today, as I was going to try to swap injectors over to see if the misfire 'moved' but I couldn't pull the injectors from the rail - I didn't want to break owt & I was wary of he time for setting off to work. All electrickery connections to injectors & engine ECU looked OK and were fully home ......  :-/  :-/  :-/
