Author Topic: HDMI Cables  (Read 1708 times)
HDMI Cables
« on: 22 January 2009, 13:00:37 »
I want to link my Sky+ to the TV via a HDMI cable but there are loads about from 99p to silly money. Has anyone got any recommendations.
TIA ;)
richardirv
  • Leeds, West Yorkshire
    • Omega 2.6 MV6 2002
Re: HDMI Cables
« Reply #1 on: 22 January 2009, 13:01:46 »
Just make sure its 1.3b!! Should be fine with the ones for a few quid!! I wouldn't spend a fortune on a HDMI lead.  :y
« Last Edit: 22 January 2009, 13:02:22 by richardirv »
V6 Gix
  • Wallingford
Re: HDMI Cables
« Reply #2 on: 22 January 2009, 14:27:46 »
Have a look on http://www.dabs.com/ProductList.aspx?ExposedRefinement=11002&NavigationKey=11125&CategorySelectedId=11125.
Anything between 20-40 quid will get you what you need. If you go too cheap mate, then the picture quality will be reduced. It all depends on what you're after I suppose, but look to spend about 30 quid.
I use a Belkin HDMI cable and paid about £40 for it and it gives really good picture quality.
« Last Edit: 22 January 2009, 14:28:39 by V6_Gix »
I hate to advocate drugs, alcohol, violence or insanity to anyone, but they've always worked for me
PaulW
  • Somewhere near Manchester
  • Come on you fiend!
    • Some crappy Insignia
Re: HDMI Cables
« Reply #3 on: 22 January 2009, 14:36:40 »
All the same unless your going over 1.5 meter's...
The 99p one will do fine tbh Pete.
You will notice *no* difference to the overpriced stuff out there...
Humbugs...
richardirv
Re: HDMI Cables
« Reply #4 on: 22 January 2009, 14:41:38 »
Totally Agree, no need to spend £30-40 on one.
Re: HDMI Cables
« Reply #5 on: 22 January 2009, 14:53:18 »
I agree to a point.
Key things to be aware of:
Screening - The cable screening is important as interference can cause data errors, better cables are likely to have multiple screened cables rather than a single overall screen.
Impedance - The HDMI signals are VERY fast with edge speeds down at sub 1ns. Cheap cable will shape the pulse. In theory this should have little impact due to the signal also having a seperate clock but, could add jitter.
Having said that, about a fiver or so will get a reasonable lead.
V6 Gix
  • Wallingford
Re: HDMI Cables
« Reply #6 on: 22 January 2009, 15:51:03 »
Yep sorry I gave you duff gen Pete. I did a little hunting around t'internet and found some really good articles about it. Basically there's no difference between a 10 quid cable and a 100 quid cable.
Here's one of the best articles I found if you're interested: http://boardsus.playstation.com/playstation/board/message?board.id=ps3&message.id=828972
Re: HDMI Cables
« Reply #7 on: 22 January 2009, 15:53:09 »
So what do I need to connect my Wii to the TV. I might as well get the proper cables, ive been using scart leads to connect the Sky + and Wii.
richardirv
Re: HDMI Cables
« Reply #8 on: 22 January 2009, 15:54:53 »
« Last Edit: 22 January 2009, 15:55:43 by richardirv »
Re: HDMI Cables
« Reply #9 on: 22 January 2009, 16:19:43 »
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=350146757385&ssPageName=ADME:B:EOIBSA:UK:31
Re: HDMI Cables
« Reply #10 on: 22 January 2009, 18:32:44 »
So will I notice the difference using HDMI cables?
Re: HDMI Cables
« Reply #11 on: 22 January 2009, 19:13:32 »
No because they are not HDMI cables on the wii......you will notice a difference on the componet over the out of the box stuff composite stuff and will be able to select the higher output res in the setup screen to
STMO123
Re: HDMI Cables
« Reply #12 on: 22 January 2009, 19:30:51 »
I agree to a point.
You took the words out of my mouth Mark. ::)
Re: HDMI Cables
« Reply #13 on: 22 January 2009, 19:39:11 »
For the Wii's graphics, 2 baked been cans and bit of string will probably do. Sky HD to hd tv use hdmi, only way to get hd picture with that source, cable should have come in the box and been used at install...?
Re: HDMI Cables
« Reply #14 on: 22 January 2009, 21:11:08 »
Sky HD isnt..........1080i or 720p at best and thats with a fair wind.....rarely achieves that due to bandwidth restrictions.
